Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Does not pump water out or spin after first wash
After the wash cycle the machine does not pump water out. hence it would not spin.
If i drain manually and manually turn it to the spin cycle, it does not spin either.
thank you for your prompt response.
  • rpersadfl Dec 17, 2008
    I had a feeling that this may be the problem but was seconded by your comments and expertise.
    Thanks a lot!!
    keep up the good work.
    Just save a bunch of money.I had gone to the store to buy a new washer since this one is 9 yrs old but was told that I had to apply for credit to get an extended warranty for free.Even though I was paying cash they did not want to extend the warranty. I came home and decided to go on line and give it one more try before heading back to the store tomorrow.
    Thanks again
  • Anonymous Dec 17, 2008
    water keeps running after it drains.
  • 36 Answers
Dear Customer
Please perform the following
The first thing to check is the lid switch. Open the lid and you'll see a recessed spot that a tab on the lid fits into. Put a screwdriver into the spot, press down and see if you hear a click. If you don't, the switch is bad. That's if you're lucky.
It could also be something as serious as the transmission. Try this: In the search box at the top of the page, type in repair (brand, like ur Whirlpool or anyother etc) washer. A list of sites will come up with a bunch of troubleshooting tips and repair instructions. I used this to fix my washer a couple of weeks ago. Good luck.
Please rate this,Thank u
Posted on Dec 17, 2008
Yep, that's it!!! Thank you, thank you, thank you. I'm not what a new switch will cost, but it's off to the appliance parts store tomorrow.
Posted on Mar 20, 2009
Thank you so much for your help. I think I lucked out and it's just the switch because it does drain the water out and spin when I push the switch in with a screwdriver.
Posted on Mar 16, 2009
    President:
  • Whirlpool Master
  • 2,651 Answers
Your lid switch is more then likely no t engaging, can you hear a "clicking" noise, when opening and closing the lid???without thinking the door is closed, the machine for safety reasons wontdrain/spin.
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
The washer will not drain water during the rinse and spin cycle
The pump is not switched on during the cycle and this circuit must be traced from the timer output. However if the drain works well in the last cycle then the pump is alright. Hence the pump circuit switch during the rinse and spin has to be traced and confirmed. Good day
Aug 12, 2010 | GE Washing Machines
My kenmore 1110.20702.990 washing machine fills up, washes, and does no more as to draining the water.....timer problem and can I get a repari part?????
If it is the timer you could manually turn it to go through the cycles. Most likely it is the pump. If the pump won't drain it won't spin hence it will stop right after the wash cycle. Pumps are fairly easy. Unplug the wasker. Remove as much of the water as you can. Pull out the unit and shut off your water supply hoses. Take off the back. The pump will be clamped to the largest hoses. Put towels on the floor once you take off the clamps all of the water will drain out. Replace the pump. Call Sears to get the new pump. Hope this helps-good luck.
Oct 19, 2009 | Washing Machines
My washer fills and runs tru the washing cycle then stops. It won't go thru any other cycles, won't spin and does not make any noise. Is it the timer?
Does it drain?? If not then you need to replace the pump. The pump drains the water hence allowing the spin cycle to engage. Sorry for the bad news.
Oct 17, 2009 | Washing Machines
ALL FUNCTIONS OF WASH CYCLE WORK EXCEPT WATER WONT DRAIN AND SPIN CYCLE WONT WORK,
Pump is blocked or shot
Pressure switch made telling the machine it is full of water hence no spin.
Drop hose into bucket to drain the water off and the machine should spin, you may be better dragging the washer to an outside door and let all of the water run away at once .
Make sure that the drain hose is unclipped from the back of the machine so that the bottom of the hose is as low as you can get it
Jun 25, 2009 | Roper RAS8445KQ Top Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
230 people viewed this question
Dan Webster
Dan Webster
Sal De
