Question about Canon imageCLASS D320 Digital Copier
Cannot find freesize feature within its paper size tool
According to the manual a freesize feature should appear within the paper size tool but I can't find it, appear only the other features such as LTR, envelope, etc.... How can I add this freesize tool to the printer?
Will deeply appreciate your help. Thanks Doc T
    President:
  • Canon Master
  • 1,447 Answers
Press program key your copier panel board
man head logo
  1. select paper size setup
Posted on Aug 17, 2009
  • Sazeed Computer
    Sazeed Computer Dec 01, 2009
    Press program key
    choice paper size
    press + /- then show A4 or Free size when saw Free size then press OK.
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
My Canon IR1610 is giving wrong paper size message when i used legal size paper(8 1/2 x 13) but it does work on letter size.I did change the value by pressing additional function and set it to LegalR.It...
u have to choose freesize from the bypass tray and then measure ur paper and enter the size in XY.then only u can use it and that too from bypass tray only
Jul 11, 2011 | Canon Office Equipment & Supplies
Canon PC D340. The display says supply rec. paper tray: freesize. I have tried disconnecting the printer and reconnecting it but it has not worked. Can you tell me how to solve this problem...
Because the paper size of your software like Word is "custom", and the paper size setting of the printer is "ltr", the printer won't print until you change the paper size to "freesize". Change it in "Additional Functions" menu on the printer (Canon D340). (Word will change the paper size setting automatically if you adjust the margins of your paper too far)
Mar 31, 2011 | Canon PC-D340 All-In-One Laser Printer
How do I select paper tray 2
You can set the Brother machine to automatically select the appropriate paper tray based on the paper size or you can manually select paper tray1 or 2. If you use the Auto Select feature, the application will automatically pull from the appropriate tray based on the document#s paper size. For this feature to work, the tray settings must be definedfrom the machine#s control panel. For instructions on how to configure this setting, continue to the section labeled: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING)
PART 1: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING
1. On the Brother machine, press MENU.
2. Scroll to and press GENERAL SETUP.
3. Scroll to and press TRAY SETTING.
Oct 29, 2010 | Brother MFC 6490CW InkJet Printer
Paper jams always appear
According to the top of page 13 of http://h10032.www1.hp.com/ctg/Manual/c00696169.pdf,
Avoid paper jams
To help avoid paper jams, follow these guidelines.
● Remove printed papers from the output tray frequently.
● Prevent curled or wrinkled paper by storing all unused paper flat in a resealable
bag.
● Ensure that paper loaded in the input tray lays flat and the edges are not bent or
torn.
● Do not combine different paper types and paper sizes in the input tray; the entire
stack of paper in the input tray must be the same size and type.
● Adjust the paper-width guide in the input tray to fit snugly against all paper. Make
sure the paper-width guide does not bend the paper in the input tray.
● Do not force paper too far forward in the input tray.
● Use paper types that are recommended for the HP All-in-One.
Dec 02, 2009 | HP Photosmart C4180 All-In-One InkJet...
H2 error when printing from pdf to A3 in multipurpose tray
H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
Here is the info from the factory service manual:
H2 The length of the paper set does not
match that of the paper actually taken
up and fed in.
• Load paper of the correct size again
according to the set paper size.
• Turn OFF and ON the Power Switch.
• For copier tray: Slide out and in the
paper tray in which the size error has
occurred.
• For Manual Bypass Tray: Place paper
in the Manual Bypass Tray.
• For Multiple Bypass Tray: Unload
paper from the Multiple Bypass Tray,
then reload it back again.
Nov 23, 2009 | Minolta Di152 Laser Printer
I can't print a letter from my microsof office word program. the printer works but when i try to print t6his letter i doesn't Hp photosmart c5280 all in one printer scaner copier , ineed and up date...
Check if the correct paper size is selected according to the letter size that you are trying to print,select custom size and give the specifications of the paper manually.
Open Solution center software on your PC, click settings>Printer settings, in the feature tab you have an option named Paper type, select plain paper and then click ok and close window and Solution center and try to print.
Sep 27, 2009 | HP Photosmart C5280 InkJet Printer
Darkening the copies
Here's information from the HP manual:
Use the copy features
The HP All-in-One enables you to produce high-quality color and black-and-white copies on a variety of paper types, including transparencies. You can enlarge or reduce the size of an original to fit a specific paper size, adjust the darkness of the copy, and use special features to make high-quality copies of photos, including
borderless copies.
Press Copy repeatedly to display the appropriate menu. The following menus are available:
– Number of copies
– Reduce/Enlarge
– Copy Quality
– Copy Paper Size
– Paper Type
– Lighter/Darker
– Enhancements
– Set New Defaults
2. Press the until the appropriate setting appears.
3. Do one of the following:
– To change more settings, press Copy.
This selects the current setting and displays the next menu.
– To start the copy job, press Start Color or Start Black.
To save the current settings as defaults for future jobs
1. Make any needed changes to the settings in the Copy Menu.
2. Press Copy repeatedly until Set New Defaults appears.
3. Press until Yes appears and then press OK.
This should help you.
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Canon imageCLASS D320 Digital Copier Logo
75 people viewed this question
old marine
old marine
