Question about Kenmore 43142 Front Load Washer
Kenmore he2 front load washer
Washer is "stuck" in mid-cycle and will not drain and spin. Manual suggests a drain hose issue. Have tried to drain and spin, machine seems like it wants to do this, but can't. Tried all troubleshooting options, nothing has helped. After a few minutes, all lights around cycle choices flash. What's the deal?
  • 33 more comments
  • Che 59 Dec 13, 2007
    machine will not drain and spin and locks the door so that it will not open. Also an F02 and suds code comes on. I've tried several time to rinse and spin again and the door will not open. I've also taken off the drain hose and checked for obstructions and found none.
  • isgtech Jan 20, 2008
    That is the same problem I have eighteen months after purchase. Will not drain until several resets of the machine. Water then slowly trickels out the dain tube until it stops and shows error lights flashing again. Power off and select drain spin until it finally finishes the cycle after several times of this procedure.
  • Anonymous Feb 10, 2008
    We emptied the trap next to the pump, found all kinds of change.  The washer started up again, then during the drain/rinse cycle it just stopped, all lights came on and the motor like it wants to run, but isn't.  Any suggesstions?
  • Anonymous Feb 18, 2008
    I tried resetting the washer several times. Usually it woks, but my wife wants it "fixed". I'm looking for a solution. I probably need to replace a circuit board.
  • washer12 Apr 08, 2008
    Yes I have the same problem. What was your solution???? Does not say on the website.
  • Anonymous Apr 13, 2008
    Washer was not draining and all we did was take the panel off the front and unscrew the drain hose and found all sorts of crud in there and it works fine now!!!
  • Anonymous May 07, 2008
    waher wont drain flashes messages "sud"
  • Anonymous May 14, 2008
    How do you take the front Panel off?
  • kevandkristi May 18, 2008
    F02 flashes, does not drain.
  • bishopvtm May 26, 2008
    My washer is stuck in washer cycle. Manual says it is a drain issus as well and suggest unclogging drain hose. But hose is not clogged.
  • mamaeich Jun 10, 2008
    I can start the cycle and soon the lights flash and the add garment, rinse and clothes clean lights stay on. I can restart the cycle but continues to happen. I have checked the manual and checked the drain hose but it is fine. What am I missing?
  • rklehn Jun 29, 2008
    it seems as if my problem is similar inn that after a few minutes all the lights are flashing.
    first issue is that when the washer is turned on water is not discharging in the drum, also the add garment light is on and will not turn off.
    i've unplugged, turned off and on serval times with no real response.
    Thanks, Randy.
  • mmr7754 Jul 02, 2008
    my "add garment" light is on. The machine sounds like its working, but there is no water coming into the machine. we ckd the hose and there is doesnt seem to be a prob... please help !!!!
  • helbent55 Jul 15, 2008
    HELP! can't open the machine, tried turning it off, but nothing happens
  • Anonymous Jul 16, 2008
    washer will not drain or spin. Door will not unlock and F1 is flashing on the panel
  • lindagiff Jul 19, 2008
    My Kenmore HE2 front load washer turns on/off by itself. When you start a cycle, washer stops, unlocks and turns on/off by itself. HELP!!
  • Anonymous Jul 23, 2008
    stuck in mid-cycle, no draining, no rolling, no washing, full-load of water. everything else seems to be normal. Tried to get someone to fix it. $79 just to show up. This site explains what a piece of junk this machine is. http://www.appliancejournal.com/applianc...
    very angry why ge/sears makes and sells this. even angrier at their price of the defective parts >$200. will never step in Sears again, and will recommend anybody if i got a chance
  • hootsville Jul 29, 2008
    Received a washer and went to use it, the add garment light stays on and the door locks, but the tub does not spin and I don't see any water going into the machine.
  • Anonymous Aug 27, 2008
    Washer stops midcycle and flashes trouble code for drainage problem. When attempting to drain it makes a loud whine/grind noise just before it dies. I beleive there would be a drain pump to drain the water after the wash cycle, but I need to confirm this before I rip it apart and replace it.
  • Anonymous Sep 04, 2008
    TUBE WILL NOT SPIN
  • kskinner1241 Sep 08, 2008
    Kenmore HE3 Flashes F2 which means a drain problem. Took off the back and we can't seem to find the filter. Had Sears once before, and it cost us $120 to fix, but noone saw him fix it. Can someone help us and tell us where is the filter?
  • Anonymous Oct 29, 2008
    my washer will not spin and drain water from clothes have only had couple mos and now this is happening after spending the money for a front loading washing machine i would appreciate any help with this problem
  • pedro1967 Nov 24, 2008
    Copy of earlier post....
  • Anonymous Dec 01, 2008
    the fix was great -- Thank You!!!
  • hubble999 Jan 13, 2009
    I cannot get my washer to drain.,,,I cleared the drains...what a mess.....HELP
  • Anonymous Feb 20, 2009
    had the same problem. If you read the manual does not help much. Ends with calling Sears for service. Thank God for the internet and people like this. I took off 2 of the 3 screws in a couple of min. the third one was put in at a 45 degree angle so it took @ 10 min. Took off the panel below the door where you load the laundry and behold a list of all of the error messages. Took out the pre-pump filter by turning counter clockwise with the garbage bag to catch the water. Thanks for the tip. lots of lint and coins. Put the filter back in. It has a tab to stop you from screwing it in too far or not enough. doing a load of laundry right now.RMISQU
  • Anonymous Mar 01, 2009
    Washer was in mid cycle and started making a horrible noise. It sounded like a helicopter. Followed directions in the book and still the drum stopped spinning and the clothes were soaked. Called for service, and they suggested we unplug it for 10 minutes and restart it. I still is not working. They are coming to look at it on Wednesday, today is Sunday. Purchased machine and had it delivered in January it is now March 1, 2009.
  • margrette sibaja Apr 08, 2009
    I have the kenmore elite and have the same problem as everyone else. I get the F2 error and the machine is no longer working. I disconnected it and am looking for the famous 3 screws under the door. Where are they? I have no idea which screws everyone is talking about ... hellppp plzzz
  • jhereg10 Apr 11, 2009
    Second time this has happened. The first time, the service person from Sears came out and it was an item that had somehow made its way into the water pump and jammed it. For some reason it appears the pump suction is not adequately protected against items working their way into it. Now it is doing it again. I'm going to try to disassemble and troubleshoot it myself.
  • Anonymous Apr 18, 2009
    Stops in mid cycyle and sounds like it wants to explode! Will not drain.
  • Anonymous May 03, 2009
    Wow, just what I needed to fix my machine. And no frustrating service call either. Thanks!
  • stovall2 May 06, 2009
    I have the same problem - flashing 21 - I did what everyone else did by cleaning the drain out and there was a lot of stuff - coins, pins, etc., but it still won't run any cycle - the pump  motor is on but no water comes in or out and the drum won't spin.....comes back with the same error - F21??
    Help - Please......
  • workermark May 14, 2009
    Awsome info, the fix was easy 10-15min. Definately a lot of water came out, in addition to $5.01 2 large paperclips, lint, 2 bracelets and an ear-ring. My wife is soooooohappy. Thanks
  • basqueman May 23, 2009
    same problem can someone help
Open the panel with 1/4 in socket. Turn white plastic cap filter counter clockwise. remove debris. replace. Run rinse and spin cycle. reopen cap and check for any new debris. replace filter cap and put cover back on. put $65 in bank. Send note to Eddie Lampert and tell him that Sears sucks and he'll never save it as long as they keep screwing their customers by not telling them about a simple fix like like this to an obviously common problem.
Posted on Jan 28, 2008
  • schupmanns Jul 15, 2011
    Great help with the same problem. Thanks for the clear directions. Got several dollars worth of change alomg with a bunch of other **** from my pockets
  • Barry Van Ankum May 07, 2013
    Thanks for the help. I took off all the covers first though - - - It's the front bottom cover. This should be in Sear's manual as regular maintenance. I had a fair bit of change and some nails in there as well - not to mention the remains of a kids sock
UNPLUG THE WASHER!!! Take off the front lower panel... three screws at the bottom. The drain plug is on the right/center. The pump motor and drain hose to the right of that. Unscrew the drain plug... counter clockwise... it is going to be a little tight, but go slow. Have a pail ready to collect the wash water still in the machine. The drain plug comes out with the trap. In it you will find items that are clogging the drain. Clean out the trap. You may also have to make sure the pump rotor is not jammed. Wiggle your finger to feel if the rotor spins and find if there is something there. If you need to clear the pump rotor... very common: The rotor and drain hose are to the right of the trap. To the left of the pump rotor is the pump motor. Twist off the pump motor by turning counter clockwise (toward the front). It will be tight but go slow and steady. The pump motor and rotor will clear the drain section allowing you to remove whatever has fouled the rotor. Replace the pump motor in the housing, taking care that all sections of the twist closer are tight. Replace the front panel. Plug in the washer and get to your chores!
Posted on Jan 25, 2010
  • pghnanay Oct 26, 2010
    Thank you so much for mentioning to turn it counter clockwise, mine was on so tight and I was afraid that I might break it...so seeing that small thing was a HUGE help. I plan on cleaning ours out every 6 months now (only 15 cents, but baby socks galore!)
  • chubskulit Nov 11, 2010
    Thanks a lot for this tip, it helped. You are 100% right on the oney,.. Thanks for saving us $$$.
GIRL TIPS!
Cleaning the filter of your Kenmore HE2t series washer - hard to get to.
Okay, I'm a girl, so I'm going to explain this in GIRL TERMS. :-)
  1. Put the phone down and DO NOT call the repair people.
  2. Get a bucket or batter bowl and a plastic measuring cup. The 1 cup size is best.
  3. If the machine is not on a pedestal, get a big black plastic bag.
  4. Get some plastic - a plastic grocery bag for example. This is for catching screws.
  5. Get a cup or SOMETHING to put those screws in and place where you cannot possibly knock them over.
  6. Borrow a 1/4" hex socket if you don't have a set.
  7. Shut your cat up in the bedroom because he can't help with this, but he really wants to.
  8. Wear latex/nitrile gloves.
  9. UNPLUG washer.
  10. If your washer is NOT on a pedestal, slide some plastic WAAAAY under it in case you drop one of those tiny hex screws. You can just pull it out, retrieve the screw, and put that plastic back under there!
  11. The hex screws are on the far left, far right, and center at the bottom of the kick panel. You have to do this by feel if you don't have a pedestal - and you CAN do it.
  12. Carefully place EACH hex screw in a cup as you retrieve them. Make sure that cup cannot be knocked over!
  13. Once all three hex screws are out, push the panel down and pull out from the bottom. You'll see two plastic pegs on the top of it - they fit into holes.
  14. You'll find an instruction booklet taped in a plastic bag in that panel. Put it in your file cabinet.
- to be continued -
Posted on Jun 23, 2010
  • 1 more comment
  • GrandMere Jun 23, 2010
    GIRL TIPS!
      size is best.
      catching screws.
    9. UNPLUG washer.
      fit into holes.
    - to be continued -
    - continued from GrandMere -
    Apologies for that double post - can't think what happened. And I cannot post further, so I created a new account just to get it done. Weird. Okay - here's the rest of the list for girls.
    1. IF YOU CANNOT OPEN THE WASHER DOOR (if it's automatically locked), you'll have to pull the tab to trip that locking mechanism. Here's how:
    2. - a) on the RIGHT side (the side of the door handle) reach UP inside the door - waaaay up until you're pretty sure you couldn't possibly reach any higher.
    3. - b) reach just a bit more!
    4. - c) you'll feel some wires and things... on the left side of all that is a teardrop-shaped plastic tab.
    5. - d) give it just a little tug and you'll hear a little click. Done!
    6. Open the door and get out as much water as you can. Whatever you don't get out of the compartment will come out of the filter casing. What a mess!
    7. The filter is in a white cylinder - you'll see it in the lower right area perhaps 2" in diameter? A bit more maybe? Here's a side picture of it - I can't find a photo of what you'll see front on. http://www.repairclinic.com/dbimages/000...
    8. Be SURE to situate your black plastic bag so water won't get into the machine or on the wires. You can stuff some towels in there - and get that plastic in there really well. I wrapped it around the cylinder so it wouldn't run back into the machine on the outside of the cylinder.
    9. You'll see that you can grasp a sort of plate in the center... rather like a shoulder-type thumb screw. Turn it counter clockwise. It is VERY hard to turn! Don't move the pump... just unscrew the damn thing. Turn it enough to get a trickle. If your machine is not on a pedestal, you'll want to collect the water with your measuring cup and put it into your bowl or bucket. I got several gallons - I DID NOT want them all over the floor! If it's on a pedestal, you can just situate your bucket under the thing.
    10. When the water stops trickling, unscrew the filter completely.
    11. Pull the filter out and clean it. It will be a mess!
    12. When you put it back, be sure to line up the little tongue and groove on the bottom of your filter basket. The filter sits in the cylinder just like a basket - when you push it back in lined up correctly, you can screw it in and it will remain oriented correctly.
    13. Make sure it's snug - then put that damn kickplate back. You definitely need something to catch the screws! You'll drop them if you're doing it on the floor - by feel.
    14. Pat yourself on the back and put in a load of laundry.
    15. Let kitty out of the bedroom so he can inspect your work.
    16. Buy your own hex bit socket set. Here's one: http://www.tooltopia.com/sk-hand-tool-49...
    17. Brag to your husband/boyfriend/brother/dad.
    18. Have a glass of wine/cup of tea and sit down with a good book.
  • marg littlejohn May 07, 2013
    How do you get the pump out? I see 2 rubber type mounts but not sure if I twist or if there is a screw somewhere.
  • 67 Answers
If u havent been check pockets before loading the machine there is a Great chance that the water pump is clogged. U need a torx 20 to take three torx screws off the toe panel under the door. hose clamp would be good to have if no a bucket will do.unplug the machine unscrew the other torx screw holding the pump in place. pull it forward undo the pump trap door and let everything fallinto the bucket and reverse the operation..
Posted on Mar 24, 2007
I had a similar problem, but actually had the pump completely fail. I had the same three machine screw front. Opened it up with the large trash bag (THANK YOU FOR THAT RECOMMENDATION!), there was ALOT of water coming out, would have been a real mess without that bag trick. I had tons of change and lint and debris clogging the filter trap, but unfortunately that didn't do it. As soon as the washer went to spin/drain cycle I could hear the pump try and then stop and the flashing lights began. So then as suggested above, you can twist the pump motor and pull it apart. A simple electrical plug comes out and you can see the impeller in the pump. My impeller would not spin smoothly and I could see where it has been wearing and spinning out of balance. Further inspection I pull the impeller and magnet assembly out of the pump and the magnet itself was broken. I since ordered the part direct from Sears. It took about 10 days to get here, $60 for the part and about $15 for shipping. The water pump with housing is Part # 8540024.
Replaced the pump and everything works great. It's much much quieter now too. I think if you hear a louder vibration type of noise, this could be the pump going out. Our pump was making this loud noise for several months before finally giving up.
Anyhow, mine wasn't a simple "Clean the filter", it was a "Replace the broken pump", but it's still very very easy to do, no reason to pay someone to do that.
Posted on Jul 20, 2009
  • race123 Jun 06, 2011
    I had the clogged catch screen problem and fixed that about two months ago but now I got the same error message and the screen wasn't plugged. The propeller seemed to but stuck on the pump. I fiddled with it a little bit and put it back together and it worked...... for about two weeks. It did the same thing. After repeating the steps above I got it working again but seemed to notice I makes a louder noise than it really should. I think it is on it's last legs so I ordered a pump tonight - should do the trick. - thanks
We have the Kenmore HE2.
The problem and solution were the same for me, too. It's had problems off and on with the lights & display flickering, but recently it began stopping mid-cycle and not draining water.
Took the 3 screws off the bottom front plate and saw the big plastic hand-screw pump access thing ... had a bucket handy & unscrewed it slowly, allowing the trickle to drain into the bucket & tightening it each time the bucket was full to stop the flow. (it worked great until i got over zealous and opened it more, causing the water to pop the plug out & my bucket to overflow onto the floor).
as was the case with others, our problem was a sock and a lot of change. after cleaning those out, i rinsed the stopper for a long, long time ... getting rid of a lot of built up black grime.
ran a short load afterward & it worked great.
thank you all for sharing the solution!
Posted on Dec 05, 2009
The suggested repair totally worked for me - a first-time appliance repair person. The hardest part was finding the right torx 20 tool and taking off the screws. I fixed it in about 15 mins. thereafter and saved at least the $65 Sears service visit and got it done faster than the 2 weeks they said they could have someone here. It would have been a DISGUSTING mold problem by that time with the full load of clothes in the locked washer - ick! One suggestion - I used a large plastic bag to collect the water, etc., once I disconnected the drain pipe filter cover. Couldn't fit a bucket underneath and otherwise it would have been a floody mess. Thank you, thank you for this great solution!!
Posted on Sep 24, 2007
Ironrunner
You just saved me two weeks of plotting the destruction of Sears at the laundry mat! Thanks.... Next time I see the sears guy I will kick him in his **** for not just showing me this to begin with.
Posted on Mar 09, 2008
Thanks for the posts and the helpfull hint of using a garbage sack. I couldn't believe the amount of junk trapped, including one of my toddler's socks...good reminder to always use garment bags.
Posted on Feb 17, 2008
CORRECTION!!
I said for machines with locked doors:
WRONG! Not inside the DOOR. DUH. Inside the front panel. My apologies.
  • JohnHenson Jun 23, 2010
    Uh... John Henson is the other account for GrandMere. Created it when I couldn't finish my post. Maybe I'm just not smart enough for this!!
    I need some coffee...
I am a recently widowed mom of 3 who had this problem. I followed the steps above. Had some trouble getting cover off, propped washer back on a Tide bottle and made it easier. Wasn't prepared for the amount of water though. Had trouble getting white cover off due to amount of lint, sock and money. I am SOOOO happy. If I can do it anyone can!!!
Posted on Jun 23, 2008
Ironrunner & Olyjim...you guys ROCK!!! That was the easiest repair I've ever done. Now I'm gonna cancel the repair call and take my wife out to dinner with the $65 I just saved, plus $1.65 I found in the drain. She has finally calmed down about this whole ordeal. Imagine.....an entire day waiting for me to get home from work to fix the 2 year old washer. Her nerves are shot!! LOL Thanks again!
Posted on May 09, 2008
I had the same draining problem as the others. All the suggestions were helpful. I used a silicone loaf pan as a funnel into the bag it worked great! We found: $2.26 in change, the under wire from a bra and about 9" of pre-caulked bath tub sealer, go figure. Thank you all.
Posted on Feb 19, 2008
We have a HE2 model 110.464625 and it would not drain after washing a rug. I was dreading trying to fix it. However, from other posts here, I took off the front lower panel held in place with 3 small hex head screws............and found a screw-in clean out plug looking me in the face. Since we had the stacked units sitting on a 8" riser, I got a bucket under the cleanout, unscrewed the plug and cleaned out all the junk.....but be careful, if there is water still in the washer, it will surge out when the junk is cleaned from the end of the line! Easiest fix I've ever seen. Great design (but NO mention of it in operating manual for fixing clogged drains!).
Posted on Dec 12, 2007
We had the same problem; lights flashing, not draining, not continuing to finish the cycle. Ours had three 1/4" machine bolts holding the cover on. Once those were off I just unscrewed the cleanout plug and out poured some of the smelliest water and about $3 worth of nickles and pennies! It took about 15 minutes and now we can clean our clothes again! Thank you to everyone that contributed to this solution!!!!
Posted on Jul 07, 2009
  • PJ CHAMBERS Aug 14, 2011
    After calling Sears and they told us it would be a minimum charge of $129 and wait over one week before they could do the service call, I found this on the internet, tried it and it worked like a charm --- found a charm bracelet, several nails, screws, change, etc. clogging it up. Thanks to all the posts saving me $$$. PJ
THANK YOU!  I first got the Error Code F-21 and did the fix it in the manual with no luck.  Later, I tried a rinse-only cycle and got error code F-01 immediately.  After reading this discussion, i fixed it in only 10 mins!  THANK YOU.   It is only 3 screws under the door of the washer and unscrewing a big drain trap.  A LOT of water came out which I caught in a bucket (my washer is on top of the drawer).
Thanks for helping!
p.s. I yielded $0.25, a bobby pin, a crumpled piece of paper and lots of weird lint.
Posted on Oct 27, 2008
Suggestion 17 saved me. My washer wouldn't drain, or finish spinning. I know about the filter and cleaning it, but I failed to check up to the right- out the pump exit from the filter reservoir. Sure enough, a big wad of string was rendering the pump useless. The pump was very hot. I unplugged the electricity, then I dug the string out with hemostats, and now my washer is up and running again. Thank you soooo much.
Posted on Sep 17, 2008
I had the same draining problem as described by others, but the drain pump filter was not plugged. Instead, a large rubber band had somehow gone through the filter and was caught in the pump propellers. In my model (110.46472501), the pump can be turned and then pulled off of the filter apparatus by depressing a tab as the pump is turned (although I only learned this after taking out the pump and filter apparatus together), and the pump can then be cleaned. A perk in taking off the toe panel: attached to the inside of the panel was a trouble-shooting guide "for service technician only" which does include checking the drain pump filter for this problem.
Posted on Apr 20, 2008
  • Michael downes Oct 19, 2011
    Thanks for helping me fix my washer at no cost ! You rock
Thank you so much, it worked. I just want to let others know it's not just lose change, I actually had a sock in the trap door of the pump.
Posted on Jan 20, 2008
  • anamejia32 Apr 29, 2012
    We had the same problem, I just un clogged ours it had a sock and loose change. Apparently we have lots of problems with these washers I really regret them, I have many more problems with that order just a very long list. It was very helpful now she is working thank-you!!
This works!! they don't tell you anything about it in the maual of course....but it unclogged it beautifully. plastic bags work well to catch the water..ideally a two person job!
Posted on Jan 14, 2008
    New Friend:
Sears has lost my business forever, and I have almost purchased my own Sears store piece by piece over the years (I'm 68!)
Their products don't last at all. From cordless drills to washing machines...they all break before they should and cost a fortune, at Sears Parts prices, to fix. They actually charge you $5 for a stinking screw!
After my old top loader Sears machine died after a fairly reasonable life, I thought I would upgrade to a front loader thinking it would agitate clothes better and save water. Well, you can't pre-soak your clothes and you can't just spin dry a load without also rinsing it. The cycle times are outrageously LOOOONG! if you choose anything but Express Wash at 28 minutes.
My washer stopped draining too, so I have to do a wash cycle, then pull the drain plug out to let the water out, then spin/rinse the load to get the remaining water out, then put the drain plug back in and spin/rinse again to get the clothes rinsed, then pull out the drain plug to get the water out with another spin/rinse.
I pulled out the entire drain and water pump assembly and their was nothing in it because I had been taking the drain plug out so frequently. The water pump seemed okay too.
I forced water through the drain tube to see if it was clear.
Found a new water pump on Amazon for $75 versus Sears price of $85 PLUS their outrageous shipping prices.
If I can't get the present pump to work, I'll have to buy an new one and you can't even be sure the replacement pump will last for very long.
I would rather buy a very old Maytag top loader from back when they made excellent machines and pay whatever it takes to rebuild it. It's either that, or I'm going to buy disposable clothes.
Stop buying from Sears! The new management has destroyed their quality of products, reputation and any trust I ever had in their service people which are now merely local repair crooks they recruit for service calls. They lie to you and rip you off more often than not.
Sears only offers you an expensive repair program when you are out of warranty and their machines are designed to fail right after their very short warranty periods.
Posted on May 06, 2013
Same problems as above .. But water seems to me pouring from the machine from many places.. What do I check next and how does that stuff get in the drain !??
Posted on Dec 02, 2011
Wow - Thanks for all the help.
The easiest fix in the world. Why isn't this in the manual they give with the washer!
A blonde super model could have achieved this simple task! What po's me is the fact that the really helpful info is taped to the inside of the panel you need to remove, left there for the $80/hr repairman to find! But thanks to you guys and my internet surfing wife, 5 mins. and no lost cash, my clothes are again clean!
Posted on Oct 15, 2011
    Problem Solver:
  • 5 Answers
The correct drain problem solution has already been posted above, so I will just add: we have a swimming pool so I used our pool pump stuff, Jack's rubber gasket lubricant, on the rubber gasket and it turned very smoothly when I reinstalled it. Also, we do not have a pedestal so I had to lift the washer and put 2 by 4 lumber chunks under the front two legs so I could get at the screws with a ratchet to get the front kickplate off. When I cleaned out the drain catch it was FULL including coins, a sewing needle, bandaids, a small eyeglass cleaning cloth, 5 lollipop sticks
Posted on Sep 15, 2011
How do I unclog drain of the Kenmore Front Load Washer, Model # 110.47512601.I fix my problem i removed the bottem font in u will see a big white clean out hose
Posted on Nov 05, 2010
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
Posted on Jun 01, 2010
Glad to find this resolution online, since the instruction manual had nothing about the issue. I removed the 3 screws from the bottom pannel (that was a bit of a challenge since one of them was pointed down and I couldn't unscrew it unless the washer was propped up) and drained all the water into a black plastic garbage bag, making several trips to dump the water. Found one small stick, a fun size Almond Joy wrapper, a Hershey Kiss wrapper and a pair of panties! Started the washer back up, works fine now :)
Posted on May 02, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 11 Answers
Machine not draining and leaking when in drain mode. HE2 machine. Removed front lower panel (2) 1/4 inch hex head screws. Access to filter is directly in front. About 3 inches in diameter with a hand hold. Be sure to put a plastic bag and towel below to catch all the debris and water. Turn counter clockwise and pull out. Be sure to check inside and try and spin impeller. Clean out debris. Lube the O-ring with liquid soap for easier instal. Run washer on rinse/drain cycle and again remove filter to check for debris. Clean again. Lube O-ring and instal filter. Replace lower panel. Preventive procedures: Check pockets, check for loose buttons etc. Place smaller items (baby socks are a real problem) in a laundry net type bag. Routinly check filter every 6 months or year. Very good design by Kenmore.
Posted on Feb 27, 2010
Wash cycle ends and spin cycle and drain to not initiate, timer continues and ends with wet laundry not drained, how an I check the pump for possible clog ?
Posted on Feb 07, 2010
  • Donald Bowdler
    Donald Bowdler Jun 02, 2010
    Top of the morning Fix it fellows. Thanks for the update, actually, I figured it out by myself and sure enough about 5 dollars in change and a few pieces from my kids plastic toys were found and releasded from captivity. Your input about the garbage bag to catch the water is a brilliant suggestion, needless to say I needed a number of towels after my repair, I can only suggest that other readers take heed of that sugestion because your washer holds a lot more water than you might think..I also agree with the others that we should find a Sears rep. and slap him or her up the back of the head.Thanks again for your input, sincerely, Gordon.
This worked great. No service call saved $80. Found $13.54 in change among screws, pencils, pins and a bullet, gonna buy some well deserved Tim Hortons coffee with the cash!! Thanks for posting the solution.
Posted on Jan 09, 2010
I had the same problem and it was driving me nuts! My husband removed the front kick panel, and we opened the filter trap. We found THREE toddler socks, a bobby pin, two zipper pulls, a 3 inch long stick, a button, and $ .98. Bummer it wasn't more money and less socks. I will be purchasing a lingerie bag for the toddler socks tomorrow!!!!
Posted on Nov 26, 2009
THANK YOU So Much!!!! I Am Woman!!! Hear me ROAR Wait till I tell Mr. fix it who is out of town and I was desperate! A 1/4 nutdriver worked for me instead of the T-20 but at least I know what those are now... I got $2.27, 2 big screws, bobby pin, a clip and...a 2008 license plate sticker tag!
Posted on Aug 20, 2009
Thank very much everyone for this fix I have been on this 2 days and I cant beleive it was a simple clogged drain plug under the front lower panel. 3 screws open the drain cleaned the slot machine LOL
Posted on Aug 31, 2008
Yay! I love it when i am really busy trying to get things done and my washer stops working! But... the advice on this site was right on! My washer would not drain or spin. So... we took off the front cover and pumped out the water from the drum and the hose by squeezing the soft hose that attaches the drum to the pump.
Then we cleared out the hose, but didn't find a main culprit. The water that came out when we pumped it was murky, looked like lint.
I will say that I had just washed a very fuzzy sweater...whoopsies!
Thank you , thank you for the advice. Easiest fix ever!
Posted on May 17, 2008
My boyfriend and I just finished following the instructions online to correct this same problem, and it worked!!! We were trying to solve this problem from the back of washer and thank goodness we did not try unscrewing anything from the back of the machine. We finally went to the web and found your helpful solutions. The Sear instruction manual is terrible, it states it is a hose clogged problem, but does not tell you how to get to the drain. I think the lack of information is a plot by Sears!!! Call me paranoid!!! Anyway, thanks for the helpful solutions, we used a cake pan to drain the water in, because it was so low to the ground, My boyfriend is very proud that he fixed this without a repair person, he is struting around like a proud peacock! You guys!!!!
Posted on May 05, 2008
Thank you so much.  I have never even tried to fix an appliance before.  Sears was going to charge me 75 dollars just to have someone come take a look at it and it took me 15 minutes to fix myself.
Posted on Mar 18, 2008
Same scenario as alot of the comments, my wife washed a rug and then it would not drain...kept getting SD and f01 codes which shut the machine off half way through cycle. I followed the instructions and the wahser is working great now................ BIG THANKS
Posted on Mar 01, 2008
Many thanks to the poster of Solution #5.
This did not solve our problem, but put us on the right track. Here's the story.
We were disappointed to find only one penny and some dirt. No slot machine in our house! We were about to ditch this solution, when we looked inside the white drainage tube, and up the black hose (which collects water from the bottom of the washing bin). Something metal caught my eye, and, after removing the black hose (metal clamp loosens by squeezing together) I found a full size open safety pin (2"). I didn't think much of it, until I reached up the hose further and found some kind of ping-pong ball. I'm guessing that the ping-pong ball blocks the black hose when the water has drained, and this somehow signals the drain pump to stop. Our open safety pin must have stopped the ping-pong ball from creating a seal, so the washer wouldn't spin because it though it was still draining. A very random problem, but an easy solution! The black hose was somewhat difficult to re-attach, so I recommend vice-grips to help you in the small space.
Thanks, again, for saving me from paying $200 to have the repair man tell me, "You need a new computer board."
Posted on Aug 28, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore he2 plus stops during wash cycle
What is the maximum capacity (laundry weight load) of your washer? And how much weight do you consider a large load, that you are placing in the washer?
Dec 31, 2013 | Kenmore HE2 Plus Front Load Washer
My he2 kenmore clothes washer does not go into spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
Machine won't spin clothes dry. I've tried the
remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Aug 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Apr 26, 2009 | Kenmore Washing Machines
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Kenmore 43142 Front Load Washer Logo
16,815 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
