Question about RCA H100 MP3 Player
Fat eror plz conect ums device fomat
Not sure whats wrong
  • lgbear Jan 06, 2009
    Yes I have the same problem, my RCA says FAT error, please connect UMS device format..
FAT Error on Insignia MP3 player
ok kathlessk
do one thing
go throught disk management and locate your mp3 digital player.
try to format it fat file system
it must work after this
ok...
Nov 20, 2009 | Insignia Audio Players & Recorders
N72 data base corrupted
hi
u have just restored the phone to its factory settings
but if you do not mind losing data on the phone then you can try a hard reset
* Switch Off the device. * Press and Hold down the keys Green/Talk + 3 + *. * Switch On the device. * If everything goes well then you will see "Formatting" screen. Note: Please make sure that your device is fully charged before you proceed with formatting the device. If the battery goes down during this procedure, It may result in inconsistent state of your device.
hope this helped
cheers
pls rate the solution
Jun 28, 2009 | Nokia N72 Cellular Phone
Format the phone
to format your 5300.. try using the code 12345.. i have the same problem,,, but i already fix that problem]
Jan 12, 2009 | Nokia 5300 Grey Cellular Phone
Fat error plz connect ums
my mpc 983 say fat error connet ums how i can fix
Mar 11, 2008 | Audio Players & Recorders
RCA H100A
drop it about 2ft on hard surface if it does not work try other way
Feb 27, 2008 | RCA H100 MP3 Player
Mp3 not working properly
Try connecting it to the computer then fomating it. so it starts all over.. it should work
Jan 15, 2008 | RCA H100 MP3 Player
LG JM53 FAT error PLz connect UMS
i don't know how to get my songs to play on my mp3 player i tried but all the songs i put on there are m3u how do i switch to from m3u to mp3
Jan 14, 2008 | Audio Players & Recorders
RCA H100
This may sound stupid but, it worked. I dropped it from about two feet onto our kitchen floor and it turned on. I am sorry if it makes it worse... but what do you have to lose
Jan 12, 2008 | RCA H100 MP3 Player
Broken rca h116a mp3 player
i formatted my rca h116a 6gb on a vista and i got the "fat error! plz connects ums device format hdd" then i used it on xp and formatted it then it reset then worked properly try xp not vista
Nov 11, 2007 | RCA H116 MP3 Player
RCA mp3 H106
Here's how you fix it for rca H106:
use the user maunal so you know what I'm talking about. I got the FAT error! Plz.. and I could still get the icons. This is how I fixed it. Go to settings and go to advanced press play once only. Plug into computer and it wil recognize it as a flash drive. Completely Format the drive then unplug the player from computer. It will switch back to previous setting automatically. If you need to update drivers and firmware use the auto updater from http://www.voxxsupport.com/images/downloads/autoupdater.exe
Aug 29, 2007 | Thomson H106 MP3 Player
RCA H100 MP3 Player Logo
165 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
