Question about Microsoft Zune JS8-00001 Digital Media Player
My zune software keeps sayin restart after setup
And i have restarted many times and it still says it i also have completly uinstalled everything and reinstalled numerous times and it says the same thing still this problem started when i updated my software to 3.1
  • Anonymous Jan 31, 2009
    how can i restart my zune
If you have already restarted your computer after the zune install\update... in your program files\zune folder you will find a zero byte ZuneReboot.bin file. Delete it. Start your zune software. try{for(var lastpass_iter=0; lastpass_iter
Posted on Jan 27, 2010
  • pjcoregon Jan 27, 2010
    ignore the code at the end of the above post... it is something fixya's software posted when it was trying to determine if I was a user.
Does anyone know how to fix error 5 code?
Many Zune users will tell you of the dreaded error 5.
When the error occurs it means that the Zune has encountered a problem that it cannot recover from and informs users to contact customer support.
Usually to fix this error, the Zune must be sent to Microsoft. If the Zune is under warranty and the owner is within the US, this is little more than an inconvenience.
If the owner is outside of the US this is not and option and if the warranty has expired, the fix can come at a high price.
However, before sending a Zune off to Microsoft for fixing, there are a number of things to try.
The first thing to try would be to restart the Zune.
The steps to restart the device vary based on Zune model. For the Zune HD player, the user should press and hold the on/off button for roughly ten seconds and the player will reset.
For the non-touchscreen models of Zune, the user should unlock the hold switch.
Then, press and hold the back button and the top button of the Zune pad. The device should restart and the user can release the buttons.
If this does not fix the error, then the user should try reinstalling the software on their Zune device.
To reinstall the software on a Zune HD, the user should press and hold the on/off button for about ten seconds.
When the device restarts, the user should press and hold the "Media" button until the message "Connect Zune To Your PC" displays on the screen.
The user should make sure they have the most up to date Zune software installed on their computer and connect the Zune.
Update the Zune and it should be ready for use again. If the user continues to experience problems, then the Zune HD software may have to be completely deleted and reinstalled. Doing this will completely delete everything on the Zune, so anything that has not been backed up will be lost, including purchased items.
To do this, the user should hold down the on/off button again until the Zune HD restarts.
Upon restarting, the user should immediately press both the "Media" and the "Home" buttons until "Connect Zune To Your PC" displays.
The user should then connect their Zune HD to a computer with the most up to date Zune software and update the Zune.
For the non-touchscreen Zune models, the following step will erase user data (including purchased items), so a backup is recommended.
First, the user should unlock the hold button.
Then the back button and the top button should both be pressed and held down.
The next step varies by model. For owners with a Zune 4GB, 8GB, 16GB, 80GB, and 120GB, the Back button, Zune pad, and Play/Pause button should all be pressed and held down.
The user should continue to hold them until they get a "Please wait" message.
For owners of the Zune 30GB, the Back button, the left side of the Zune pad, and the center of the Zune pad should all be held down until "Please wait" displays.
After data is cleared, the message "Connect Zune To Your PC" will appear.
The user should connect the Zune to a computer with the most recent version of the Zune software installed on it.
After the software is installed, the Zune should be ready for use.
If these measures fail to fix error 5, then the Zune owner will likely have to send the device to Microsoft as the problem is deeper than a software issue.
Sadly, it is not always clear what causes error 5 to occur. In these cases, there are few other options than to leave it to the experts.
hope this helps
Oct 05, 2012 | Microsoft Zune JS8-00001 Digital Media...
I want to start over with my Zune Model 1089. I want to clear everything off of it and start over. Please help....
1. Slide the "hold" switch so that it is in the unlocked position. 2. Press the "Back" button and the top of the Zune pad at the same time and hold until the device resets and begins to power up. Release the buttons when the Zune starts to power on. 3. Immediately press and hold the "Back" button and both the left side and the center of the Zune pad and continue to hold until the Zune restarts. The phrase "Please Wait" will appear on the LCD screen. Release the buttons.
4.Let the Zune continue resetting. It will clear the contents and eventually display "Connect Zune to your PC" when it is ready.
5. Connect the Zune to your PC via the sync cable. Follow the prompts given by the Zune software to completely restore the Zune device to the factory settings. If you have downloaded newer Zune firmware, you have the option to restore the Zune firmware with the latest version.
Mar 06, 2011 | Microsoft Zune JS8-00001 Digital Media...
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
Mi zune 120, modelo 1376, marca error "5", y que contacte el servicio de soporte, Como se soluciona eso?? MEx D.F. Bryan M
  1. Restart the Zune player. To restart the player, follow the instructions for the kind of player that you have:
    • Zune HD player: Press and hold the on/off button for about 10 seconds until the player restarts.
    • Non-touchscreen Zune player: Set the hold switch to the unlocked position, and then press and hold the back button as you press the top of the Zune pad. When the Zune device begins to restart, you can release the buttons.
  2. If you receive the same error message when you restart the player, try reinstalling the Zune player’s software.for more information go to
http://support.microsoft.com/kb/926993
Jun 27, 2010 | Microsoft Zune JS8-00001 Digital Media...
Zune won't respond to any key presses.
I would first allow the Zune to completely charge (the battery symbol should be full and green[i believe--it's been a while since I first got mine]).
I would then unplug the device and restart the computer. Once your computer has completely rebooted connect the device to the computer and see if it detects the device. It should work. Also you might try another USB port.
Jun 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
It keeps sayin clean disc and restart
You should clean the discs and restart it. Or blow out your console with some canned air. If this doesn't help csll X-Box
Apr 29, 2009 | Video Game Consoles & Games
Error code c00d124d appears on my zune while sync
You may have to attempt a Hard Reset if this issue is persistant.
This will erase everything on your device, as a warning please be certian you have backup copies or this is a last resort.
Here is the original post:
WARNING: A hard reset will delete everything on your Zune.
  1. Press and hold the back button
  2. Press and hold up until it reboots
  3. Depending on which Zune you have, immediately do one of the following:
    1. If you have a Zune 4 GB, Zune 8BG, or Zune 80GB, immediately press and hold the Back button Back at the same time as you press the right side of the Zune pad and the Play/Pause button. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    2. If you have a Zune 30GB, immediately press and hold the Back button Back at the same time that you press the right side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    Good luck, Let us know
Apr 14, 2009 | Computers & Internet
When i plug the zune into my computer, it won't recognize it
It's a glitch with Microsoft. All 30 gig units are affected. It's a leap year and the extra day threw the software. Let it discharge overnight and plug into your computer in the morning to load. Microsoft is supposed to have a fix. Thousands are affected.
Jan 01, 2009 | Microsoft Zune JS8-00001 Digital Media...
Broken zune
i get the same exact problem what i do is restart my computer and plug my zune into a diffrent usb port(i have 4...2 in the front and 2 in the back) and my back ones work fine try that and let me know if it works
good luck
~Temp
Aug 28, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Windows Doesn't Recognize??
I had to restart my pc and download the software 3 times before i could start using my zune. I hope it works for you. If not check to see if your pc meets the requirements for the zune.
Jun 25, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
455 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
lugnuts1
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
