SOURCE: Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
SOURCE: can't figure out how to
just use an adjustable pliers wide enough to grip the outer small edges. Grip, turn counter clock wise and remove. The other way to do this is unscrew the panel behind the filters and you should be able to reach the neck of the bulbs.
