Question about GE JVM1440 Microwave Oven
Microwave runs but does not heat
Have a GE JVM 1440, the microwave runs but does not heat
  • 3 more comments
  • jerryginny20 Dec 17, 2008
    everything works as before it just doesn't heat,we put a cup of eat water in and the turntable turns, light comeson, fan runs, but the water does not heat,tnx
    Hi just ck'd agin, sounds like I have a Hum also not a loud hum but i can hear it tnx
  • jerryginny20 Dec 18, 2008
    thanks for the help the wife says she put coffee pot with a metal band around in the microwave to heat the coffee,just a thought
    thanks for the help, will buy a new one and replace it, as it is old anyway..merry christmas
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light, cooling fan and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • GE Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 17, 2008
  • William Miller
    William Miller Dec 18, 2008
    The metal band would not have caused any trouble unless it arced or the pot was empty.
  • William Miller
    I would be interested in buying your oven's control panel assembly before you scrap the oven!
    At
    Once the control panel assembly is removed, there is no toxic material in what's left, and it can be left at the curb for scrapping, recycling or freecycling.
    Feel free to contact me directly (and please remind me of your
    full model number) if you're interested.
    I can pay with PayPal or money order, as you prefer.
    Thanks!
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: my GE Microwave Model JVM
Hi
Please check if any fuse is blown inside the microwave. If the fuses are fine then the issue is with the door switch of the microwave, it may be faulty or may have loose connections. If the switch is faulty then you can get it replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 12, 2011
JVM 1440 GE microwave stopped heating. all other functions work great. where do I start
GE microwaves are notorious for the magnetron failing, this is what generates the microwaves. Usually the unit will make a louder than normal deep hum when running if this is the case, but not always. If you have the schematic, you can measure for 120 volts leaving the control board to the transformer, you can simply measure the line in on the transformer for this. You also want to visually note that all other functions like the countdown timer, inter light, turntable, and fan are all running when you start a cooking cycle. The monitor, and interlock switches mounted on the latch assy need to be checked for continuity too. If replacing the magnetron we always recommend replacing the high volt diode connected to the capacitor and chassis ground. Pleazer Appliance...
Jan 14, 2015 | GE Microwave Ovens
I have a GE spacemaker microwave oven model JVM 1440. A bulb blew and when I went to change both over the stove bulbs stay on all the time. What is the problem and what should I do.
there is some kind of circuit board damage. carefully check for burned foil paths on board; around where the relays are. if so, you may be able to "bridge" the broken foil paths with solder. just unscrew the bulbs in the meantime.
Aug 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 02, 2010 | GE JVM1440 Microwave Oven
Microwave oven runs but does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ftsd
Jun 22, 2010 | GE JVM3670 Microwave Oven
Can i vent my jvm-1440 microwave/fan ?
yes, you can recirculate it out the front which i suppose u do currrently... you may also vent it out the top, or the rear. to do this u must drop the unit down,and rotate the fan motor to point the appropriate direction, and also install or have a exterior venting piping existing currently..
Apr 16, 2010 | GE JVM1440 Microwave Oven
Oven runs does not heat GE EMO3000
the microwave runs does not heat the model is jvm 1660BB003 KW:1.58
Dec 05, 2009 | GE Microwave Ovens
My GE spacemaker JVM 1533BD microwave runs but will not heat
heatman101
stysty
Mar 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker JVM 1440 Watt microwave has F4 error code.
Have GE JVM1440BH light and fan that are operated by the touch pad do not work. Both stop working at the same time. Ideas????
Mar 21, 2009 | GE Microwave Ovens
Microwave GE SpacemakerXL JVM 1450
If you need to ask how to do this task, you may have no idea of the extremely high voltages that exist under the cover, even when unplugged. I would advise a competent person changes it for you.
Aug 26, 2017 | Microwave Ovens
GE JVM1440 Microwave Oven Logo
2,889 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
