Question about Toshiba Gigabeat F41 (40 GB) MP3 Player
Gigabeat 40GB screen frozen
I think I removed the USB cable from my computer too early and the screen on the Gigabeat machine is now frozen and will not respond to pressing any button. I have tried to turn off the battery also to no avail. I think that the software is stuck. The only thing I can think to do is to remove the battery. Is there any other solution?
  • cardan Nov 20, 2007
    Have gigabeat MEGX30 show system error 00000030 on screen cannot do anything with it
    Help needed.
  • mflb Dec 19, 2007
    Can anyone help? error 00000030
I was loading some songs onto my gigabeat s30gb and unplugged it too early and the screen was frozen on the battery is low. it wouldnt respond to anything i did. i tried reseting it by flicking the black switch underneath it. this worked fine and i didnt lose any of my files.hope this helps
Posted on Jul 28, 2007
  • 32 Answers
Well, it would be really easy to take off the battery. The battery is simply plugued with a little 3-pin wire, u just pull on it and put it back in. Now to open that gigabeat, its pretty easy. I even got some images for u. Go at this website (its for the F10 and u have the F40, but its the same thing): http://www.angelfire.com/bug2/gigabeat/
Posted on Jun 29, 2007
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
How do i upload music from my pc to gigabeat 40gb i pod
To transfer music files to your gigabeat, simply connect it to the PC via USB cable. A gigabeat window will pop up on your screen and will direct you to WMP 11 (make sure to click the "Complete" button, or it will not take you to WMP 11). Once you're in WMP 11, assemble the list of music you wish to transfer and press "Sync". The program will automatically begin transferring data to your gigabeat.
Mar 01, 2011 | Toshiba Gigabeat F40 40 GB MP3 Player
Toshiba Gigabeat-U MP3 Player suffering "USB ERROR #203"
try reinstalling any software that come with it.
try a different usb cable.
try different usb ports.
Jun 28, 2009 | Toshiba Gigabeat MEG201 MP3 Player
Problem with USB cable
Have you tried connecting it to another USB port?
Sep 19, 2008 | Dell PowerEdge 2600 Server
Frozen screen on Gigabeat S30
I left the Gigabeat on until the battery ran out. It then turned itself off automatically and allowed me to re-charge the battery. When I turned the Gigabeat on, it again worked perfectly,
Jun 23, 2008 | Toshiba Gigabeat S30 MP3 Player
Toshiba Gigabeat 30gb
If you stored music on a hdd it should be safe. If all else fails, remove the hdd and connect via usb to a computer to retrieve the music.
Jul 03, 2017 | Toshiba Gigabeat MEG201 MP3 Player
Gigabeat windows gone
Try formatting the drive. Use either RealPlayer, Windows Media Player or Media Monkey to synchronize your music. You can drag and drop, but I dont advise that as I believe that leads to crash and format itself. DO NOT remove the USB cable while it is uploading. If you need to stop synching, you must first close the programe you're using before disconnecting.
Nov 09, 2007 | Toshiba gigabeat S MP3 Player
Gigabeat frozen!
Hi Lorna, Yeah I found my Gigabeat froze a few different times when I was getting used to it. Solution: at the bottom of player there is a little battery on/off switch - its tiny and black but you would have needed to switch it on to first use it. Well turn it off here for 10 seconds and the on again. This removes all power from the hard drive and circuits which occassionally freeze. Hope that helps
Apr 23, 2007 | Toshiba gigabeat S MP3 Player
It thinks its still plugged into the USB
Turn the battery button to the off position. It seems to work when I do it to mine. Good Luck.
Jan 09, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat F41 (40 GB) MP3 Player Logo
327 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
James DuPont Jr
James DuPont Jr
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
