Question about IBM ThinkPad T40 2373 Notebook
I need hinges for my T40. Any one know where a good place to get them is and should I just replace the whole sreen hinges and all? Robert
    Master:
  • 351 Answers
Dear robert,
where are you located? so that i can provide you the proper address .
Regards
Posted on Dec 17, 2008
Replacing laptop hinges
There are 2 set of cable that run from the display to the monitor, be very careful with it. In most cases, to remove these cables you need to disassemble the whole laptop. Now, since you are on Y changing the hinges, I think you can do it, just don't pull on the monitor too hard, and it needs to be place on a flat surface very close to the laptop. It's not that hard, you just need to be careful, that's all.
Jun 20, 2013 | Gateway 7330GZ Notebook
A pin broke on the rear window hinge. do i need to replace the pin only or replace the whole hinge?
hi.
the only time i have known these hinge pins break is when they seize solid in the hinge due to corrosion.
even if you can get just the pin, the corrosion would normally still be in the hinge, and will eventually cause problems with the new pin.
i would just change the whole hinge, you know that there will be no further problems from that hinge.
Apr 10, 2011 | 2003 Ford Explorer
Need display hinges for ibm thinkpad t40 type 23734cu
i have a pair of hinges i took off my old t40 2373 . if you want them email me at umhhmm@ gmail.com. and i could send them to you.
Jun 09, 2010 | IBM ThinkPad T40 2373 Notebook
The hinges on my skimmer box flap have broken need 2 new ones. Can I purchase them without having to buy the whole part.
Depending on what model and brand you may be able to replace the hinge but a replacement will cost less than twenty dollars to get an universal weir all you need to do is measure the throught or bring the old one with you. The new one will have spring loaded hinges that you just pull the pins and the spring will push the hinges into place.
Jan 30, 2010 | Waterco Cover, Skimmer Beige 9 7/8" Oem...
The hinge on the lid to my black oval crockpot broke off; the whole thing has been rendered basically useless
The lid hinge is only a convenience thing. Most crock pots don't have hinges. So, unless the hinge affects the functioning of the pot, It is really not rendered useless. If you don't want to buy a new one or can't find a replacement hinge then simply clean up the break so it doesn't interfere with place the cover on. Good luck
Aug 21, 2009 | Crock Pots & Slow Cookers
Thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Jan 18, 2009 | Thermador C301U Electric Single Oven
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
RE: How do I replace the LCD screen hinge on my IBM T41
here is the manual from IBM http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46464
Sep 17, 2008 | IBM ThinkPad T40 2373 Notebook
2002 Audi TT
Nothing special at all - just remove the back cover on the headlamp and you'll see inside that the bulbs are pinned in place with hinged metal wire clips. Release the clips and the bulbs should come right out.
Sep 15, 2008 | 2002 Audi TT
IBM ThinkPad T40 2373 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
