Question about Maytag Atlantis MAV6000 Top Load Washer
Loud clackety sound when spinning
My Maytag washing machine, model no. MAV6200AWW, is making a loud clackety sound when spinning. I recently cleaned it by letting hot bleachy water soak the scum out of the drum & now it is making this sound.
Maytag washer model MAV6200AWW
pop off the front panel and look at the inside of it,if you see black dots on the bottom half and on the other walls like half way up from the bottom you have bad tub seals,the seal is made of metal and rubber,when it leaks and in spin it will shot out water and it will be black from the rubber,also you can fill it as high as it will go,then turn the timer to spin and watch where the tranny.and tub meet,if it sounds like marbles spinning and grinding and water leaks out it's the seals.if so time for new washer
Jun 23, 2013 | Washing Machines
Washing machine agitates, rinses, but does not spin
Is the motor running but the unit will not spin?
Nov 09, 2012 | Washing Machines
Does a maytag model mah2400a have a drain filter i have a sour smell an have tried vinager bleech and baking soda nothing has worked any suggestions
It has a strainer. These strainers are evidently designed to make washers stink. Your strainer is located behind the kick panel, below the main panel. The strainer is located between the drum and the pump. It is connected to the drum with a rubber hose. Unplug your washer. Pull and clean the strainer, While the strainer is open, look up into the pump suction cavity and remove any loose debris that you see in there. Reassemble the strainer, replace the kick panel.
Clean the door seal face with a bleachy water solution, let it sit, and wipe it down again. You want to get the solution into the grooves behind the seal face, and wherever you think mold and mildew might be on/in/behind the bellows seal.
Put one cup of bleach directly into the washer tub.
Fill all of the dispenser cups with bleach.
Run the washer on your hottest setting (no clothes). I use the sanitary setting with an extended wash.
When the cycle is finished, run another cycle with nothing in the dispenser cups or tub, Just plain hot water, this will flush out the bleach residue. Most folks wipe their bellows seal face and grooves down with bleachy water regularly. (1X / wk).
Hope this helps. Best regards, --W/D--
Aug 10, 2009 | Maytag Washing Machines
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
There are hoses on the back of all washig machines that connect cold and hot water. If these hose were put on backwards you will not get hot water. Check the back of the mchine there will be a C=COLD AND H=HOT.
Jan 19, 2009 | Maytag SAV5701A Top Load Washer
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Aug 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whining during spin cycle
Could be a loose belt, or drum bearings,or ( drum rollers if your model is so equiped) In my mind machine would be worth repair when needed.
hope this is helpful
Jan 17, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Atlantis MAV6000 Top Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
