Question about JVC XV-S502 DVD Player
Power immediately shuts off
I am having some kind of power problem with this machine. When I turn it on, it immediately powers off. I was only able to open the drawer to get my DVD out by using the "open" button on the remote. I had to press it 4 or 5 times to get the drawer open enough to pull the DVD out. I have unplugged the power cord for a while, plugged it in a different outlet, and tried doing a reset (plugging in power cord while holding play+stop). None of them worked. Has anyone else experienced a problem like this? How can I tell if it is the power cord or something inside the player? I really like this player and hope it can be fixed, but I don't know where to start. Thanks in advance if anyone can help!
  • 1 more comment
  • Anonymous Jan 18, 2009
    I have the same probklem
  • Ioavva Mar 24, 2009
    The power immediately shuts off and the standby light lights up. The drawer will not open at all and it's not MY dvd in there!
  • Pam Haskamp
    Pam Haskamp Feb 28, 2016
    same problem
  • 68 Answers
You have something in the power supply. are you a tech person? if you are. open the device and unplug the power board from the rest of the device. turn it on and see if this happens again. if it does, then you have a problem with power unit in you device. I would say a capacitor is at fault somewhere..as I said before if you are not a tech person, take it to a repair man. good luck
Posted on Apr 01, 2007
Laser printer shuts down immediately
A laser printer that shuts itself down immediately after turning it on indicates either a loose power cable which can be fixed by pushing the power cable in properly or something internal to the printer is causing it to shut down.
If it is shutting down due to something internal, one possability is it has the wrong power going into it. a 110 volt power supply going into a 220 volt printer or the other way round change the supply or find a converter for it. Another possibility is some other component in the machine is failing such as the power regulator board or format board. If it is something internal like this. Replace the printer is really your only option unless it is still under warrantee as replacing parts in most machines nowdays is more expensive than buying a new printer.
Aug 19, 2014 | Brother HL Office Equipment & Supplies
It wont switch on
try to remove the battery , then press and hold power button for 8 secs. Then insert the power cable instead of battery. Turn it on. If it wont, try to disengage the power cable and insert the battery. If still wont turn on, kindly inform toshiba about this problem and have them fixed immediately. It is either the battery, the cable or the pc unit itself that causes your laptop failure...
Mar 01, 2011 | Toshiba Satellite C655-S5139 Notebook
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
Printer immediately loses power when turned on. All lights light up and then machine immediately shuts down. Like there is a short or fuse problem.
this problem is your power suply i meen logic card problem so chek your printer main logic card. chek EST or capiter.on board.
Dec 20, 2010 | Dell Laser 1720 Printer
Computer shuts down immediately after I turn it on.
First look for the obvious-make sure it's plugged in to a power source and make sure you got enough battery power. Nothing?
It immediately shuts down, because it's telling you it needs to be taken in to have the Apple dorks fix it, as this is not something that can easily be fixed on a web site. Opening this thing up with hands on fixing is required for your machine, but keep in mind that your warranty is void if you spilled water on the laptop.
Nov 02, 2010 | Apple MacBook Mac Notebook
After a while running it shuts off. fans seem to be working but, not sure if 100%. Does "the professor" work for this type of problem?
I had the same issue with my desktop HP Pavilion. It turned out to be a faulty power connection in the actual power cable right where it connected to the powersupply in the back of the computer. I had the power supply go out on the same computer - new one is about $30 for a replacement - installation is extra. To determine if it's the power cable you can power up and wiggle the cable right at the back where it plugs in. If it drops off immediately then you'll need a new cable. To determine if the power supply is faulty unplug the unit, take the cover off and measure a spare white connector coming off the power supply. You should have +- 5 volts and +-12. If you don't have within 10% of these voltages then replace the power supply
Sep 23, 2010 | HP Pavilion m7480n (882780389410) PC...
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
Tv shuts off immediately after turning on
Does it shut off shut off, or is there audio present after the lamps shut off? When you shine a light to the screen do you still see picture kind of?
If still see picture, it's inverter/power supply or CCFL bulbs itself. If no picture, completely off, it's DEFINITELY the inverter/power supply.
Sep 30, 2008 | Televison & Video
Machine shuts off immediately
your ac driver could be damage or a connector is loose
Jun 18, 2008 | Canon imageRUNNER C3220 Color Copier
JVC XV-S502 DVD Player Logo
152 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
