Question about Sharp R-1490 Microwave Oven
R-1490 fan doesn't run or unit doesn't heat
I have a Sharp microwave R-1490. When trying to use the light comes on, timer counts down but doesn't heat and the fan isn't running. you do hear it click upon start.
  • Sharp Master
  • 9,098 Answers
That would be a defective secondary interlock (bottom door switch) or its mount.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Dec 17, 2008
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Sharp R-1460A Timer counts down very rapidily and no heat
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Dec 12, 2009 | Sharp R-1480 Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
No Heat
This is probably due to a bad door switch, most likely the top one. The microwave got hot because the cooling fan was not running. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com/
Apr 26, 2007 | Sharp R-1492 Microwave Oven
Sharp R-1490 Microwave Oven Logo
204 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
