Every time I place a 2GB miniSD card (with reader) into the drive on my computer for miniSD it freezes my computer. defective card?
    President:
  • 2,110 Answers
Yes it mght be the memory card reader driver problem or memory card may be defective...
Posted on Dec 17, 2008
Unlock software
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the microSD/miniSD adapter. The SD adapters will also have a lock switch.
Sep 12, 2013 | SanDisk 2GB microSD Memory Card
Where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
I have a sandisk 2gb micro sd card. I put it into my computer's card reader and it keeps saying it needs to be formatted. When I try to format it it says windows was unable to complete the format. I am...
The FORMAT process is trying to write data to the card, but that writing is NOT successful,
i.e., the memory on the card is damaged/defective, and so it "fails".
Responsibly recycle the card, and purchase a replacement memory-card.
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Micro sd card is locked how can i unlock this ?
For the microSD card you'll need the large adapter (picture left side)
to unlock.
Insert the microSD card into the Adapter with the arrow upwards:
put the microSD card directly into the Adapter on the left.
(The Adapter on the right below is miniSD, used for other size cardreader slots)
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to put data onto the SD card (Adapter) with the microSD card in,
on the SD card reader slot of your computer
or
Pull out the microSD card and put it in your previous used device, to
see if transferring files will work.
Jul 15, 2010 | SanDisk 2GB microSD Memory Card
Nokia73 software updated locked memorycard
connect your memory card usng a card reader..to your pc....then formate it
Oct 12, 2009 | Cell Phones
Why wont my sidekick format my memory card? I have a MicroSD in a MiniSD adapter. I've also tried a second MicroSD that I happened to have laying around...Do I have to have a MiniSD by itself or do I have...
Hello , Welcome
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Aug 07, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Removal of miniSD memory card from Alias Samsung phone using fing
generally it should easily be pulled out with your finger nails....but dont try too hard as it may spoil the slot..
May 15, 2009 | SanDisk 2GB microSD Memory Card
I have a 4gb sandisk micro sdhc with adapter and the computer freezes when i have it in the sd drive.I have a hp pavilion a1 a1203w. Is there anything i can do?? Please Help
I had a similar problem not long ago. The SD and SDHC standards are different. SD only goes up to 2GB, and SDHC (high capacity) goes higher than 2GB. THe problem is that SD card readers aren't capable of reading SDHC cards, even though the card will physically fit into the card reader slot. When you insert an SDHC card into an SD card reader, the reader attempts to read the format, and locks up the OS while trying. You'll need to get an SDHC card reader and use it separately like through a USB port or something.
May 13, 2009 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
