Question about Sony KV-27V10 27" TV
My tv video is turn off but sounds perfect
Some day my tv image turn off but sounds very well while the tv is turn on, i think is a tube fail, i need to know where i can consult the price of this part for take a option to fix it or buy a new one Sorry for my english Thank you for your help
    President:
  • 1,284 Answers
You cannot rejuvinate a Sony CRT without permanate damage. The set monitors the red, green and blue cathodes for current drain. If one cathode is drawing conciderbaly less current then the other two well then a blank picture will result. You notice when you turn the TV on the timer light flashes and when it stops the picture appears? I bet the timer light is flashing alot longer than it used to. This is just a sign of a failing CRT and the TV won't be worth replacing it as Sony CRT's tend to be on the expensive side.
Posted on Mar 24, 2007
  • 49 Answers
Donot quickly replaced the tube! try this first get 2 megohms 1/2w resistor solder it between blue gun and green gun.if this make the picture still, bad tube.u can still rejuvinate it.if not,bad capacitor in vertical or bad g2(screen) adjuster.
Light gradually getting darker and harder to make out
My understanding is that an LCD TV has a fluorescent tube for a backlight, an LED TV is LCD with an LED array for the backlight. Depending on what type TV, it's possible a technician could replace the fluorescent tube or whatever and get it working again. If it's a CRT TV, you might need a new PS or CRT.
Dec 13, 2013 | Panasonic Omnivision PV-7401 4 Head VHS...
Bose Lifestyle V35, sound but no image.
Thank you so much the unplug the power from the system worked after hours of trying other stuff
Huge thank you
Aug 14, 2012 | Bose Lifestyle V35 Theater System
Sony rear projection tv kp-51ws500 no picture. Standby light blinking red 5 times. TV has sound but no picture. Before the picture went out TV was turning green then red and had curved lines going...
Blinking 5 times is a sign of at least one of the three video tubes overcurrenting, which will eventually shut off the image. It happened with me but with my red tube over-illuminating. The solution is to reduce the drive intensity on the offending tube. Remove the front speaker grill. Behind it you will find a panal with 6 pots, these are drive (brightness) and focus for each of the 3 colors. My fix was to turn down the red intensity to zero and (after a restart) bring it up slightly till the image was acceptable, colorwise. I did have to adjust all 3 intensities to get a decient color balance along with the focus's on all three tubes (the drive intensity adjustments will knock the focus out as you go). I used the auto-adjust patterns to focus on, and you may want to use a stationary image, such as a paused DVD scene or a video game, to focus on. I still haven't found a way to clear the error code, but I learned to ignore it. The result isn't perfect, but it's very acceptable and it'll do for awhile (and it didn't cost anything!). Good Luck.
Dec 11, 2010 | Sony KP-57WS500 57" Rear Projection...
I cant see any image on my tv.i think its because its blocked . can you tell me how can i see images. i just heard a sound but no images or channels.the model of my tv is 27f543.i think this is coming...
try to check the heater of your picture tube if you do not see any light glowing in the back of your picture tube your resistor is open common value is 5.6ohms.
Oct 15, 2010 | Sharp 27F543 TV
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
I tried to play it one day and the sound was on but did not work
Okay, is the sound coming out and no image/video, if so, on your AV cable at the connection to your Xbox there should be a switch on one of the sides it switches between HD TV and TV if your TV does not support HD then switch it to TV and it should work perfectly hope this helps your situation :))
Dec 13, 2009 | Microsoft Xbox 360 Console
Need a small sound board for my Samsung TV
If the sound is distorted, then you need to replace Sound board. If you do not have picture and sound, it has nothing to do with sound board.
There might be millions of reason and depends on the make and model of the TV.
On most of the samsung TV's, such problem might be due to defective Circuit Board. It can be replaced or repaired.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Samsung Remote Control
Phillips tv 32pw9544
it is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Oct 16, 2007 | Televison & Video
Screen problems
Sounds like you have caps going bad in video circuit. This will need repair from export. If tv is in warranty, then send back.
Aug 16, 2007 | Hitachi 28LD5200 28 in. HDTV-Ready LCD...
Televison & Video Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
