Question about Salton WM4 Waffle Maker
NEED OWNERS MANUAL
I bought a Salton WM4 Waffle Maker at a resale shop and dont know how to use it. Does anyone own one that can tell me how.
Thanks
Plug it in, and wait for light to go off..
When light is off, pour (aprox) 1/4 cup batter on each of the 2 (of the 4) waffle panels on the bottom surface. Close lid; then, per manual, wait about 90 seconds. The light may flicker on/off while baking but disregard. You may experiment with different times by observing "steam" from coming out of baking area.
Remove waffles with a plastic spatula (as knives may scratch the non stick coating)
When cleaning, power unit off.. Do not immerse unit in water. Wipe down with a soapy/damp cloth.
I tried using non stick spray and it seemed to make them "soggy"; it also required up to 2 mins (used a "sand timer") then flipped waffles, then another 2mins..
Posted on Apr 18, 2009
Purchase manual
Appears to be the same thing with a different model number.
http://www.salton.com/files/documents/WM-1075%20Booklet%20EN.pdf
Jul 25, 2014 | Salton WM8BEL Belgian Waffle Maker
I have a pre owned wm-4. No owner's manual. Can the plates be removed for cleaning?
These instructions are taken from a WM14 waffle maker, maybe they will work for you. It doesn't say anything about removing the plates:
"Wipe Cooking Plates with absorbent paper
towel or a soft cloth. Although the Cooking Plates are coated
with a non-stick coating, some batter or ingredients may still adhere
to the Waffle Maker. To remove, simply pour a little cooking oil onto
the baked-on food. Allow to stand for 5 to 10 minutes. This should
soften the food and make it easy to remove with absorbent paper
towel or a soft cloth. If the preceding measure fails to remove the
food residue, we suggest wiping the Cooking Plates with a slightly
dampened cloth and a little non-abrasive detergent."
Mar 28, 2011 | Salton WM4 Waffle Maker
Does this waffle makes come apart to wash? If so, how?
The manual for this waffle maker is on the www.salton.com site
Feb 28, 2011 | Salton WM4 Waffle Maker
How do you remove the plates for cleaning?
I looked for you model by using Salton WM4 and found nothing. Is there a better model number?
Closest match was Russell Hobbs
RHBW4 and RHBW4CAN
This unit is also made by Salton
I checked several Salton user manuals and none of them had removable plates. They all stated this in the use and care guide:
Cleaning
To keep your Waffle Maker operating properly, clean regularly.
1. Unplug the Waffle Maker and allow it to cool completely before cleaning.
2. Never immerse the waffle maker in water or any other liquid.
3. Wipe the exterior with a soft, damp cloth. Dry thoroughly.
4. To remove any remaining batter on the Cooking Plates, wipe with a soft, damp cloth or absorbent paper towel. Dry thoroughly.
5. Do not use steel wool, scouring pads, or abrasive cleaners, as they will damage the finish.
Jan 26, 2010 | Salton WM4 Waffle Maker
Waffles sticking in a Salton wm-4.
Salton wm-4! one of the oldest waffle maker. The waffle is generally known to be difficult to clean. I would only advice you should always grease the plate before use. This helps make cleaning easy. You can also check our post on The Best Waffle Maker in 2017 The best waffle maker 2017 Easy buying guide Kitchenutilitypro
Sep 24, 2017 | Salton WM4 Waffle Maker
I need a manual for a salton waffle maker wm4
There is a site that posts PDF files of manuals for all manner of things..manualsonline.com.
Here's the link for the Salton Waffle maker, they have several versions:
http://kitchen.manualsonline.com/search.html?q=+salton+salton+waffle+maker
Jul 28, 2009 | Salton WM8BEL Belgian Waffle Maker
Does the salton waffle maker have teflon in it?
It very well may, did the box or manual say? If not and even if it did you will still need to either spay or brush with butter to keep waffles from sticking, that many surfaces with all those corners and ditches something will stick everytime unless you lightly coat with non stick something. let me know if this helps goofballlovers
May 10, 2009 | Salton WM8BEL Belgian Waffle Maker
Need PDF manual for Toastess Waffle Maker # MOL576
I have the manual for you waffle baker. It appears to be the same as the Toastmaster waffle baker, TMRWB. If you need the manual let me know I will upload it or send a copy to you, if you like.
Mar 20, 2009 | Kitchen Appliances - Others
Salton WM4 Waffle Maker Logo
842 people viewed this question
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
Kolbrun...
Jerry Greenberg
Jerry Greenberg
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
