Question about SanDisk Sansa m230 MP3 Player
My sansa m230 all messed up i need help?
Ok it all started when i was done with my update. when i was done with it, i followed the directions and disconnected it. then when i go past song number 20 it goes crazy and turns off and turns back on, and everything is reset. i need help trying to figure out to do. some one please help me.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Hi, Try formating the sansa first. You can do so by clicking on "My computer" and then right click on the sansa drive and "Format". It will help in case the 20th song was in an invalid format. Let me know if it helped. D.
Posted on Apr 10, 2007
I just plugged in my sansa m230 and loaded some songs on it. After I was done, I unplugged it and the screen keeps flashing back and forth from "initializing" to a screen that says " Sansa m230 512 MB". I...
ok, hold the power button for 20 seconds or more. it should do a power emergency shut off. wait ten seconds and then turn it back on. BAM! it should be good.
Sep 29, 2010 | SanDisk Sansa m230 MP3 Player
Sansa m230
Try updating Windows Media Player and seeing if that helps.
Dec 26, 2008 | SanDisk Sansa m230 MP3 Player
Computer not recognizing MP3 player
We had this problem with our son's Sansa Fuze. The fix was to update Windows Media Player on the computer that wasn't seeing it. So, if you're running different versions of WMP, you might want to try that.
Dec 25, 2008 | SanDisk Sansa m230 MP3 Player
I unplugged it before it was done initializing...
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Oct 03, 2008 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230
I would recommend that you update the firmware on your device..that usually solve the problem you are having..To update the firmware, follow the link below..
http://www.sandisk.com/DriverDownload/download.asp
I hope that helps
Thank You
Computerrep
Mar 25, 2008 | SanDisk Sansa m240 MP3 Player
Sansa M230 player
you dont have to install the cd if you already have windows media player 9 or higher so just try to put songs on it with media player 11
Aug 10, 2007 | SanDisk Sansa m230 MP3 Player
Sansa m230
update and upgrade will work!
Jul 06, 2007 | SanDisk Sansa m230 MP3 Player
Sandisk m230
Hi big dee. Deleting songs from your M230 can be done by either browsing the player through your Windows Explorer and then selectively deleting the music file, or by formatting the player which would delete all of your music files. It's also important to know that your player has 2 modes -- MTP and MSC -- because music files saved in one mode would not be seen in the other mode, and vice versa. To switch the modes on your player, use the menu and navigate as follows: Menu > Settings > USB You would get a choice of "Autodetect" (this is for MTP) and MSC. Here's how to delete the files: Step 1: Plug in your player to your computer. Open explorer and check if your player is detected. Your player's LCD would display "USB Connected" and the mode would be indicated below that. If your player's mode is MTP: A. Look for the Sansa M230 icon on Explorer (it will be recognized as a Portable Audio Device). Double left click on it to browse the player. B. The player will have 2 sub-folders: "Data" and "Media". Double left-click on the "Media" folder and either find your music files or open the "Music" folder to find your music files If your player's mode is MSC: A. Look for the Sansa M230 icon and drive letter on Explorer (it will be recognized as a "Removable Drive". Double left click on it to browse the player. B. The player will have several sub-folders such as "Audible", "Config", "Record". You may already be able to see your music files or the player may have a "Music" sub-folder. Open that to check for your files Step 2 Once you've located your files, you may now be able to delete them. Step 3 Once you've unplugged your player, the M230's LCD will display the message "Rebuilding Library". Let that process complete, then you may turn on your player to confirm that the files have been deleted. To format your player, just right-click on the M230 icon in Explorer, then select "Format". When the Format window appears, make sure to select "FAT" as the File System type, and also make sure that the "Quick Format" checkbox at the bottom of the Window remains un-checked. I hope this info helps. Enjoy your M230. :)
Apr 25, 2007 | SanDisk Sansa m230 MP3 Player
I can't see or copy files from my pc to the m230
Wait for two days then try to get the files. Becoz i've faced that problem in my Sansa M230.
Apr 17, 2007 | SanDisk Sansa m230 MP3 Player
I need help with my mp3 it wont let me listen and i already tried to format it and it did not work. it still says not enough space for music db please free 8 MB. and then it says no files and my computer...
Your M230 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M230 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M230 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Computer Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Computer Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M230. The lower section also contains the drive # pertaining to your M230. Right-click on either drive letters pertaining to the M230 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M230 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M230 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M230 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M230 is a great player
Apr 15, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
