Question about Philips 25TR19C 25" TV
My tv not working with my ps2 - Philips 25TR19C 25" TV
  • kevis9192
    kevis9192 Dec 17, 2008
    no i dont no how to hook it up for it to show
  • 27 Answers
Is your tv on L2..what have you trouble shot so far?
Posted on Dec 17, 2008
We had our ps2 hooked up to an old rca tv and was using the satelite remote for it channel had to be on 00 for the ps2 to work. We got a new tv and hav moved the rca and ps2 to another place but don't...
New tv's don't use dead channels like 00 anymore for there inputs.. They use sources to change from different inputs.. Make sure you have your ps2 hooked up into input plugs on the tv and then turn it on the ps2 then look on the new controller for the tv & find a button saying source .. Press that until you see your ps2 on the screen. If not check your connections try again.
Feb 03, 2012 | RCA Televison & Video
When I plug system in, red light shows that system is receiving electrical power. However, system wont read game or turn on.
Causes: 1. You've made the wrong connection to your TV
2. You didn't make a connection to your TV
3. At worst, your TV isn't compatible with your PS2 (PAL/NTSC issue)
Remedy: 1. Check your connection with your TV. If you have a S-Video cable
connection for your TV and your PS2, check it properly so that
video cable from your PS2 is at the Video-in port in your TV. If
this doesn't work. Go to #3.
2. You probably got excited. =) Connect your TV to your PS2 by
following the instructions in your manual.
3. This is an issue. First, before buying a PS2, you should know
what type of TV you are using. It's either PAL or NTSC. PAL TVs
are most likely to be found in the European countries. As for
NTSC, it's the most common between the 2 and can be found in the
US and the rest of the world. Now, make sure that your PS2 is
compatible with your TV. Or else, you might get weird pictures
in your TV. And at worst, your TV might be damaged.
Nov 22, 2010 | Sony PlayStation 2 (PS2) Console
My son's ps2 has sound but does not have any video. The machine worked fine until I moved the t.v. with the PS2 attached. What can we do to fix this problem? Is it the laser?
Hello, I would exclude a laser problem. It looks like this is a cable problem instead. First check if the TV cable is well plugged both to PS2 and TV. Second, the cable could have been damaged while you were moving the TV, if you don't get results with the above solution, i'd suggest to get a new one at a local retailer, a PS2 RGB cable will cost just few bucks, but before buying something, I'd try the PS2 on a second TV, if have the chance. Good Luck! Peter
Aug 02, 2010 | Sony PlayStation 2 (PS2) Console
I got ps2 console 30004\pal. but has no video signal from it.
That's the Mother Board problem, you should take it to the Sony for servicing or qualified personnel.
Oct 18, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 has a problem reading certain games but works fine with others. to add to the problem, i'm playing on a old color tv which do not have remote & i can not try PAL/NTSC setting. Many times the...
i would say that it depends on the age of the ps2 mine started doing similar things sometime after 5 yrs. this eventually lead to it dying. if its a new ps2 then id say you need a new cord for the ps2 to the tv to solve the color issue and try a universal remote for the tv.. hope this helps. if all else fails a new ps2 at gamestop is like $70
Jun 14, 2009 | Sony PlayStation 2 (PS2) Console
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Apr 28, 2009 | 1991 Honda Accord
Tv will not recognise my ps2.
my playstation2 says please insert a ps2 or ps format disc and there IS a cd
Dec 31, 2008 | Sony PlayStation 2 (PS2) Console
Trying to hookup ps2 to direct TV.have found a couple solutions that didn't work.
This is not a problem with the PS2, it is configuration of the Direct TV. Be sure that the port of the TV works. Or if you are trying to connect to your Direct TV box, you it will not work if your connecting to output connection. You can only connect the PS2 to a Video Input.
Dec 30, 2008 | Video Game Consoles & Games
Ps2 wont work in my sanyo tv
Are you hooked up to be on a channel? If so can you reconfigure it to be line in or an aux setting on the tv?
Apr 21, 2008 | Sony PlayStation 2 (PS2) Console
My ps2 wont work on the TV
so back your tv input says yellow red and white should be sterio in unless its mono tv then just use white then in front hit ch down past 2 to go into inputs to see ps2 ok
Feb 10, 2008 | Sanyo DS31590 31" TV
Philips 25TR19C 25" TV Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
