Danby 60Pint Dehumidifier with Remote Dehumidifier
Problem for Danby 60Pint Dehumidifier with Remote Dehumidifier
Problems with Danby SHCC6026 Simplicity
By viperpiper on Apr 07, 2007
This the 60 Pint model that is dehumidifier, humidifier and air cleaner. I have only been using it as a dehumidifier. Until recently, when I switched it off from with the on/off button beside the LCD, all was quiet from the unit. Now when I turn it off with the button I hear a motor running from somewhere inside the unit. It only stops of course when I unplug it from the wall. Even if I just plug it back in, without actually turning it on from the front do I hear this motor running. What could this be ?? I'm not entirely sure if it's running correctly now, so I'm just trying it out since spring has arrived.
regards
P.D.
Same Problem
Jan 12, 2009
-   CAN'T BELEIVE THIS PROBLEM IS SO COMMON! i HAVE THE EXACT ISSUE
-   Guest
Jun 15, 2008
-   This the 60 Pint model that is dehumidifier, humidifier and air cleaner. I have only been using it as a dehumidifier. Until recently, when I switched it off from with the on/off button beside the LCD, all was quiet from the unit. Now when I turn it off with the button I hear a motor running from somewhere inside the unit. It only stops of course when I unplug it from the wall. Even if I just plug it back in, without actually turning it on from the front do I hear this motor
Same problem as describe above-   Guest
May 29, 2008
-   I too have exactly the same issues as listed. Often the tank remains empty until I apply pressure and then you can hear it filling the tank. It takes a minute or two (of applying pressure) and surprisingly, and quite quickly, the tank is 1/3 full. Haven't had the system too long, it ran great when we first purchased....no solution.-   Guest
Jan 04, 2008
-   I have the same problem and it is definitely the dehumified water tank pump that remains on constantly even though there is nothing to pump out. I believe the culprit is a faulty level sensor/switch. I've only had the unit for 4 months so it is on warranty. I am taking it to the nearest approved appliance repair depot for repair.-   Guest
Jan 04, 2008
-   I have the same problem too...
When I use it has humidificator, the little motor in the bottom back is making a big noise and never stop until I unplug it.
Was working fine before, but now the noise is so lound...
I don't have any leak or water on the ground, but it's just way to noisy.
-   stef1966
Best Solution
posted on Jan 15, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Mine does the same thing, and no, it is not normal. While the motor is continuously running no water even enters the collection chamber in spite of humidity levels which would suggest it should. Can the manufacturer respond????
Solution #2
posted on Dec 10, 2007
Somewhat Helpful)
tabrakadanak
Rank: Apprentice
Rating: 80%, 6 votes
It's normal, the motor is running while it's not powered on to make the water filtered in the tank.
Do you get problem with water get on the floor?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Sep 27, 2009
Not Rated)
rnbreau
Rank: Apprentice
Rating: 0%, 0 votes
e 7
Was this helpful?
Yes
No
Solution #4
posted on Jun 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I contacted the manufacturer, and they said this is not normal and to bring it in for service.
It seems to be a fault in the design, is my understanding.
Otherwise it would have made this noise in the first few days of operating it (if it was normal operation)
Popular Solutions for Danby 60Pint Dehumidifier with
Questions and Unsolved Problems for Danby 60Pint Dehumidifier with
Do you recommend Danby 60Pint Dehumidifier with Remote Dehumidifier?
Answer
Answer
I got this from my neighbor, i want to use it as dehumidifier, worked well but then the intenral... (More)
Answer
i lost the user manual and i have always `e7' flashing and not working just use it as a... (More)
Answer
Ice is building up and coming through tth efront of unit at the bottom where the filter is. What is... (More)
Answer
When the top bucket is filled for humidifying, the reservoir below it fills and starts leaking out... (More)
Answer
how do i work it where do i set the levels at
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 01, 2007
I have the exact same model and get the exact same thing. I believe it's the pump to pump the condensed (dehumidified) water up into the reservoir, and it just won't shut off ...period.. It's not even 2 years old, and I know the pump is going to eventually burn out as no water is going through it. I'm thinking it's a water level sensor, but not sure. I've emailed the company, still waiting to hear back.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby 60Pint Dehumidifier with...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
