set gain to 12 o clock top -1,low mid cut at 500 hz about -3db,80hz cut -3db...now put fader to 0db...now you have a good eq to work with...paul sound eng Ireland.
If you are using your microphone through a mixing desk try using the eq section to cut out the feedback frequency. A bad feedback usually occurs around 400k. Ideally you can should use a graphic eq but a big difference can be made using a simple channel eq.
It may affect the tone of your voice but thats the comprimise - a slight change in your voice or an annoying feedback.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 08, 2005
Cato - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Turn down microphone volume (Generally, you do not need to turn the volume up as high as you think. Ask the students to tell you when it is OK.) Try to stay behind the speakers, (or on the stage area) if possible Do not go to the spot where feedback occurred
try to keep the mic as far away from the speakers, suppose if u r in live sound ... u have to use focussed monitors to avoid feed back
Was this helpful?
Yes
No
Solution #5
posted on Nov 15, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Also, don't "CUP" the microphone with your hands. This usually causes feedback on mics.
Solution #6
posted on Oct 14, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is a great mic, but I actually had one of these lose it's ablility
to reject unwanted noises. During sound-check it was acting as if
it was an omni-directional mic, picking up almost as much of everything
in the room as the vocalist using it. I havent figured out what
happended to it yet, but will post the problem as soon as I do.
Solution #7
posted on Oct 04, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Use a 31 band EQ and dial out the frequency. You can then gain higher volume with less, or no, feedback.
Solution #8
posted on Jun 22, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you're talking about using a D112 in a live situation you need to eq out the frequency that's feeding back.
I have done the miscrophone test and there is nothing I am trying to use skype I can hear them but...
(More)
I have done the miscrophone test and there is nothing I am trying to use skype I can hear them but they can not hear me.
Hi, I have an Aspire 4736 laptop. But I am trying to use Skype but no one can here me. Does my...
(More)
Hi, I have an Aspire 4736 laptop. But I am trying to use Skype but no one can here me. Does my computer have a built in microphone or do i need to buy a headset?
I have a Sony Vaio VGN-NR475N. I've been trying to figure out if i have a built in microphone or...
(More)
I have a Sony Vaio VGN-NR475N. I've been trying to figure out if i have a built in microphone or not. In sound under the recording tab, there is a microphone icon (Realtek High Definition Audio) but it says that it isn't plugged in. So does this mean i do not have an internal microphone and must purchase one???
