Question about RCA HD52W59 HDTV Projection Television
How do you hook up a wii to this thing?
Rca hdtv, dish network, dvr player, receiver, can't make the darn wii work. getting no picture. there must be a setting somewhere that is not in the right position. any clues?
  • 1 more comment
  • Mmonet104 Dec 22, 2008
    I NEED HELP!!!!!!!!!
  • vkpatrick Dec 29, 2008
    We ended up connecting the wii to another tv, and changing the output from 480i to 480p (or vice versa) and it recognized the signal. ?????????
  • Anonymous Feb 25, 2009
    I can't get my Wii to work when plugged into my Dish DVR
    Problem Solver:
  • 4 Answers
Do you have a input place on the side of the tv that u cant really see? thats where mine was and it was the only one that would work with the wii
Posted on Feb 12, 2010
Why wont my surround work with new Dish network dvr.
When the DISH Network installed hooked up their DVR, did they connect it via HDMI? If so, then it could be a bad HDMI connection. I would bet they simply bypassed your receiver and went straight to the TV, which is why no audio comes out of your receiver. You can test this by turning on your DVR and TV. If you see picture with your receiver OFF, then they bypassed your receiver. You'll need to hook up and HDMI cable from the DVR into the receiver and then out of the receiver to the TV.
Feb 21, 2016 | Denon AVR2112CI
Can I connect the usb port on the DVR-625 to a TV with a usb connection and get a better picture? ?
Hi Roy Yoerger!
You would not be able to use the USB connection on your receiver to get a better picture. To get the best picture on our Standard Definition receivers, I would recommend using Component (RCA) cables.
Tommy Faust
DISH Social Media Representative
Feb 25, 2012 | DISH Network DVR-625 DTV Receiver /...
Have a dish 625 and hooked up new 1080p got a picture like a cartoon--fuzzy with blurry borders around images what so i do?
Hello, this is Matthew Gonzales with DISH Network customer service. A fuzzy/distorted picture can be caused by a couple different things. First of all, although your TV is 1080p HD, the 625 DVR is a standard definition receiver so the picture may not be as clear as expected. You should be getting a clear picture, but it will not be HD. First thing I would do is check the cables, making sure that any cables that you use are secured, and not damaged. If possible you may even want to try replacing cables. You can also try performing a reset on your receiver if you haven't. To reset your receiver, you simply unplug it from its power outlet for about 15 seconds, then plug it back in. Your receiver will reboot, which takes about 5 minutes. If you have performed all of these steps, or continue to have the issues, please email me at matthew.gonzales@dishnetwork.com.
Nov 29, 2010 | DISH Network DVR-625 DTV Receiver /...
I have a vip622 with hdmi hooked up. no video or audio
Hi there, my name is Mayra Diaz with DISH Network, I just ran into your post, just wanted to make sure that everything is working ok for you. Usually when this issue happens we would replace the HDMI cable first and if that would not work we would replace the DVR receiver. If you have any other questions or concerns feel free to post back.
May 15, 2010 | DISH Network ViP622 DVR DTV Receiver /...
No dish network sound through denon 1609 receiver
check the setting for the HDMI connection at the Denon you may have to assign the HDMI audio setting also on the front of the Denon while in the DVR mode press the input mode button on the front of the Denon to select auto and if that doesn;t give you sound you will have to connect a cable from the DVR optical.coaxial or analog audio output to the Denon and setup for that type of audio connection
Jan 19, 2009 | Denon AVR588 Receiver
Hooking a Wii to Dish Network reciever(not a hd tv)
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Dec 29, 2008 | RCA HD52W59 HDTV Projection Television
I want to run my DVD player through my DVR player.
Dish network receiver only have outputs. There are not any inputs on the receiver that would allow this but if your dvd player has an iput source you could run the Dish receiver to it and then the dvd player to the TV. Sorry to be the bearer of bad news. Thanks for using FIx Ya and let me know if I can further assist you.
Dec 25, 2008 | DISH Network DVR-625 DTV Receiver /...
ok u can hook it up though a dvd player if ur tv wont support it make sure ur on the right channel though
Dec 25, 2008 | EA Sports Tiger Woods PGA Tour 08 for...
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Wavy lines and jogging TV picture
it could be any of the things you listed, the coaxial output on the dvr, where it says channels 3-4 out, the cable , or the coaxial input port on your tv. the dvd player is probably hooked up with rca cables (red white and yellow) so the reason you dont have the issue with it is because its on a different port, one solution would be to hook your receiver up to the tv using this kind of cable, this would also get you stereo sound, you would then watch dish network programming on a video input channel,
if you want to narrow the problem down, i would suggest hooking a vcr up with the cable thats connected to 3-4 out, play a tape and see if the issue continues, if not the issue is with the dvr, if so try a different coax cable, if this resolves the issue, the issue was the cable, if not unfortunately the issue is your tv
Feb 20, 2008 | DISH Network DVR-625 DTV Receiver /...
RCA HD52W59 HDTV Projection Television Logo
680 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
