Question about GE WSXH208A Front Load Washer
GE frontload washer will not wash cycle or spin out
The cycle fills the tub with water, but does not begin turning the drum in the wash cycle. Tried to get it to spin cycle, still the drum does not turn. The water pump does come on and sounds like it's draining water from the tub. Motor doesnt sound like it's kicking on. Any advice? Possible timer issue?
  • 6 more comments
  • Darren Pugh Mar 26, 2007
    No, I do not hear the electronics even trying to turn the motor on. Also, I do not hear any clicking of the timer. Also if I turn the timer to final spin, the water pump continues to run even after the water is gone. Also, if I move it to the end of the whole cycle, the buzzer comes on and does not turn off by itself. Any thoughts?
  • Anonymous Apr 12, 2008
    the problemof the maytag wash mashine when washer the middle of the part it can not move
  • Anonymous Dec 29, 2008
    I cannot find guest # 2's solution, any help?
  • Anonymous Mar 13, 2014
    not calculating water properly, Too much water filling in the wash cycle. Fills over half the drum until starts leaking, then the drain comes on
  • Anonymous Mar 17, 2014
    frontloader washing machine display read spinning but tub is not spinning
  • Anonymous Mar 19, 2014
    fills with water but will not agitate, will also drain and spin; when timer goes to agitate after filling with water it sounds as if the motor is running
  • Anonymous Mar 21, 2014
    washer fills with water but fill light flashes and beeps also the agitator will not turn but water will pump out on spin cycle also the weigh (stone) on the bottom of the tub came loose and rubbed the bottom of tub
  • Anonymous Mar 31, 2014
    the model number is TAWX700PQO. Water comes in then goes directly out without washing.
Thanks to Guest #2 our laundry is back in action and we're not waiting for a serviceperson. We took the front panel off, unscrewed the white plug and was sure our plastic drawer was open to catch the water, a load's worth. We found a small screw driver, 8 or so pony holders, some change, drill bits, bark, games pieces, can tops, etc... unbelievable. Thanks SO MUCH for the hint!
Posted on Nov 22, 2007
  • 4 Answers
The solution posted by Guest (Solution #2) fixed my issue, thanks. Note: There was over a gallon of water that drained out with lots of debris. The amount of water would depend on how recently you used the machine.
Posted on Nov 20, 2007
I also have a GE front loader. Mine was doing the same thing so I called out the repair man. He opened up the bottom of the washing machine and opened up the drain in the bottom. (make sure you have a 9X13 pan under it) The drain was full of debris (coins, a couple of ball point pens, and misc) He emptied the debris out and then found that a pencil was still stuck in the tube that feeds into the drain. What happens is that the drain trap gets partly plugged and the water can't drain properly. When there is water backed up the washer cannot spin correctly and therefore your clothes come out dripping wet.
Posted on May 28, 2007
Can u here the electronics trying to reverse the motor? motor could be gone as long as timer still functioning.....
Posted on Mar 26, 2007
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
I have a GE washer model wwse3160a. It does not function except it fills with water. I checked the drive belt, I tried turning the motor clockwise and it spins the drum. All the lights come on but it...
Hello
I am familiar with this problem and 99% of the time it is caused by the washer lid safety switch, if the switch doesn't function the washer control will not let the cycle run past filling the tub with water. You can buy the part and get information on how to install it from a company called www.repairclinic.com
Sep 14, 2011 | GE WWRE6260D Top Load Washer
The water, there was no water left in the tub of the washer, but the clothes were dripping wet; and the cycle was showing to be complete. I had to re-set the dial to the spin setting inorder to completely...
What has happened is that your water pump has gone out and it cannot pump the water out of the washers tub. This is a common issue and replacing the pump is not that hard assuming you have the time, effort, tools and energy.
Jan 23, 2011 | Kenmore 24962 Top Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Washing machine will not fill with water just aggitates
Check the float bulb in the bottom of the tub and the switch below the tub. It may be stuck in the up position telling the computor that the water has filled. The timer is not supposed to advance to another process engagement until the water floats the bulb and changes the bottom switch position.
Jun 21, 2009 | GE WBSR3140DW Top Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Tub spins while in wash cycle
suspect what ge call a mode shifter pull front panel off by sliding putty knife along edge at each side and pressing clips front comes right off look on motor for a flashing green light (washer must be in operation) there are 2 wires in a single plug on motor these run back to transmission area with a volt/ohm meyer unplug and ck between the wires for continuity should be roughly 90 ohms if bad will not show any continuity
Oct 08, 2008 | GE WWSR3090TWW
GE washer model WHDSR209
On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
Hope this helps..
Jul 15, 2008 | GE WDSR2080D Top Load Washer
GE WSXH208A Front Load Washer Logo
516 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
