Question about Amana ACD2232HR Side by Side Refrigerator
AMANA REFRIGERATOR MAKES A LOUD POP!
IT HAS TO DO WITH SOME SORT OF CYCLE I THINK. IT POPS A FEW TIMES VERY LOUDLY AND WILL STAY QUIET FOR A WHILE THEN REPEAT.
ITS A 2214 BOTTOM FREEZER
  • 36 Answers
Dear Customer
Please perform the following
If it's cooling ok, they're probably normal sounds. Modern refrigerators can make many noises, most people aren't home long enough to hear them. A popping sound could be defrost water hitting a hot defrost element, or refrigerant making noise in the cooling lines. If it's working ok, ignore it. Please rate this,Thank u
Posted on Dec 17, 2008
Popping noise
it's the aluminum defroster coils cooling after a defrost cycle.
a padded aluminum foil-covered mat installed behind the defrost heater in the back of the fridge is a fix at least for Samsung I know.
Jan 07, 2018 | Magic Chef CTB2125 Top Freezer...
Loud popping sound every few minutes. Cools ok
Is your fridge self defrosting? We have one which makes similar noises (especially noticeable at night) and it's the defrost cycle.
Jan 08, 2013 | Refrigerators
Loud pop coming from roof area possible around sun roof
remove the headlining then squirt some foam filler behind the support bars ,i think they may be flexing causing the noise as this sort of fault is common the rover 75
Nov 12, 2012 | 2006 Cadillac DTS
We have a bottom freezer Kenmore refrigerator, and it makes a very loud tapping noise, almost like someone hammering. Then it will make on loud pop and quiet down for awhile.
Which is your model.
Also how about cooling temperatures are they ok.
Is the sound like the motor compressor hemmering or the fan blades hammer.
Oct 28, 2010 | Refrigerators
Noise after the motor starts
Is this a clicking or a knock/pop sound? The knock knock sound can sometimes be helped a little bit by tilting the refrigerant filter drier (located in the compressor compartment) to a horizontal position. Ask your technician to do this for you.
May 29, 2010 | Amana DRS2462B Side by Side Refrigerator
Makes a loud pop noise, and the refrigerator compartment now freezes.
sounnds like your air damper poped off the spring and is now stuck open pouring freezer air into you refer compartment'
Oct 09, 2009 | Amana ABB1927DE Bottom Freezer...
Our 10 month old Amana, Model Number Aff2534FEB1, Serial Number KW4932914, periodically makes loud popping noises. It runs and cools just fine. Are these popping noises and indication that there is...
Popping noises can result due to anything from the parts of the box expanding and contracting against each other with temperature fluctuations to the icemaker ejecting a batch of ice. It could even be noises made while the box is going through a defrost cycle. If you catch it making a popping and open the freezer door to hear some hissing and sizzling going on it is definitely defrost noise, quite normal.
Jul 13, 2009 | Amana Refrigerators
Periodically cycles through a loud humming noise.
Hi, these are the early signs of compressor failure. i would put in a service call before it completely fails.
Mar 09, 2009 | Refrigerators
Amana Mod # ABB2223DEB Refrigerator
Try damper part number W10167268 from Whirlpool. They re-engineered the part, it's works different. Whirlpool issued a bulletin to servicers, but won't cover it under warranty (I have tried for many customers) "A bulletin is NOT a recall"
Jun 03, 2008 | Refrigerators
Amana ACD2232HR Side by Side Refrigerator Logo
876 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
