Question about Amana Radarange Microwave Oven
Amana Radar Range Model AMV1154BAW
My microwave counts down at 10 times the normal speed. If I enter 90 seconds, it finishes in 9 seconds. All other electrical seems to be working fine.
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave oven replacement
Amana is under the Maytag umbrella.
Maytag customer service should be able to help but I think you may need to call instead of e-mailing.
Try them here: http://www.maytag.com/support/contact_us.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Amana Microwave
I would suspect a shorted high voltage rectifier diode, a bad high voltage transformer, or a bad magnetron, in that order.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: OTR Amana microwave- No power, lights, clock or sounds.
Either your magnetron, cooling fan, or the magnetron thermostat is failing.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Amana / Whirlpool customer service is here.
Please contact them to find your nearest authorized service center.
Posted on Jun 08, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Is there any better resource for a door handle
The Amana / Whirlpool / Maytag part number is R0713642 and you can get it for far less at one of the places listed here.
Posted on Nov 25, 2009
  • 12 Answers
SOURCE: I need a user manual for an Amana Radar range
The best place for guides is
http://www.technostation.com/modelslist/5
Posted on Aug 12, 2010
For Model: URC517MP - Can you clarify Error Code C5
Hi ess0,
The Amana error code F5 means that you have a failed Electronic Range Control (ERC. The only way to resolve this problem is to have the Electronic Range Controller be replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 31, 2011 | Amana RC17 Microwave Oven
How to clean amana radar range?
This may not be for you your exact model, but all the use and care issues should apply to your microwave all the same.
Amana Use and Care Manual
Oct 21, 2010 | Amana Radarange Microwave Oven
Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
Aug 25, 2009 | Maytag MMV4205 Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
Here is where you can download the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Yes the problem can be undone also.
Feb 09, 2009 | Sharp R-540DK Microwave Oven
Timer descends very quickly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Feb 01, 2009 | Maytag MMC5000 Microwave Oven
Microwave oven replacement
Feb 27, 2008 | Microwave Ovens
Amana Radarange Microwave Oven Logo
114 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
