I have a maytag side by side refrig., model number msd2432gr. The unit is on and running but not cooling, making clicking sounds like it's trying to do something.
  • Ken Bledsoe May 11, 2010
    Is the clicking coming from down around the bottom of frig?
  • 405 Answers
I have honestly had the same problem, if the compressor is ok it has to be the start capacitor. I can help you repair even if it is the compressor. Hope I can help you more
Posted on Dec 17, 2008
My kenmore side by side refrigator has stopped cooling on both sides, you can here is click like the compressor is trying to run it cliks about 1 or 2 seconds then clicks again like on and off.sounds to me...
if the first three numbers are 106. on the model number it sounds like the start device on the compressor is bad,part number 8201799 and it's around 55 bucks,unplug the machine,remove the bottom back panel,you'll see the compressor,there will be a metal clip,pop it off with a screw driver and then slide the start device off the compressor,if it smells burnt or if you shake it and hear pieces rattling around it's cooked,also there's a timer in the fridge side,when you first open the freezer door the fan should blow,if it doesn't the timer could be stuck in defrost,with a screw driver you can turn the timer until it clicks and it will come out of defrost,if it starts then you have a bad timer that's stuck in defrost,but i'd put my money on the start device if the clicking is coming from the compressor area and it's not starting,let me know how you make out and as long as it's warm unplug it so you don't damage the pins on the compressor
Nov 03, 2010 | Refrigerators
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side issue: Refrig works normal. However the freezer defrosted itself, food is thawed. I'd like to repair myself, what's your recommendation i.e. troubleshoot, what to look for prior to...
Pull the refrig out , and remove the back panel . Is the compressor running ? Is it hot ? Is the fan cooling the compressor , running ? If the compressor is not running , the piece on the side , with 2 or 3 wires going to it , is bad . If the fan is not running , replace the fan motor . The part number for the compressor piece ( overload/relay kit ) is 12002784 . It is easily replaceable . If the compressor is running , check the square black coil box ( condensor coil ) , to make sure it is clean . Is clean , check the fan in the freezer , to make sure it is working .
Nov 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
Good evening, My Maytag refrig/frez s/s model #MSD2756DE is very warm inside. This started after a thunder storm. It's making a clicking sound every 2-3 minutes. It sounds like a compressor wants to start...
Sorry to tell you this, but your compressor is stuck, your chance of getting the compressor unstuck is about 1%. Companies warranty their compressors for 5 years on the average. If the fridge is older than that, it doesn't pay to have someone replace it, it would be time for a new fridge.
Jun 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Apr 26, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Yellowing handles on Maytag side by side refrigerator
only solution is to relpace the handles, there are 3 parts to each upper, middle nad lower here are teh part numbers youll need 2 of each, both the freezer and refrig are the same parts
61005445 handle upper
61005494 handle lower
61005609 handle main
Jan 25, 2009 | Maytag MSD2432G Side by Side Refrigerator
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Poorly Cooling Side Bu Side
the coils are actually behind the unit next to the fan assy(sorta a plate rolled over it self opposed to conventional coils on this particular unit).tyr removing hte lower panel in freezer section, check the evaporator.Should be an even frost pattern across hte entire coil, no frost with execption of the top 1 or 2 coils, is an indication of a sealed system issue( covered under 5 yr manufacture warr usually). excessive frost (cpmpartment completly frozen over) is a sign of bad defrost system.perhaps even the fan not circulating the cold air into the refrig compartmant
Mar 22, 2008 | Refrigerators
Both compartments not cooling
It sounds like the control board may be gone. If there are no fans running or the compressor running then it will never cool of course. I don't think it's stuck in defrost mode since you say the display shows dashes vice numbers. Go to this site for diagrams, etc. Item 11 is the controls section. http://tinyurl.com/3533ao
Jan 28, 2007 | Maytag MCD2257HES Side by Side...
Heating & Cooling Logo
157 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
