Question about Frigidaire GLEQ2152ES Electric Dryer
Heating elements on gas dryer
I have read your " repairs scenario" of the dryer not heating. Great help !!!
my question is you have mentioned the thermo cut out and the high limit thermostat I can't see them as listed parts on the drawings do they go by another name? It is a fridgidaire Model GLGR341AS1 gallery
  • 5,911 Answers
Okay...the write-up you read was advice for ELECTRIC dryers. The model number you provided is for a GAS dryer. You have a burner assembly in your dryer instead of a heating element. The likely culprit on a gas dryer that no longer heats, is the igniter. The following link will shed some light on how the igniters work:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for advice on how to replace an igniter in a gas range, but the theory of operation is the same. Read the top portion of the link I provided.
The igniter will become weak with age and will either stop glowing, or will glow, but not draw the necessary current to open the gas safety valve. This is a designed safety feature that prevents free flowing gas from entering the dryer cabinet without ignition. I would recommend you check first to see if the igniter is glowing. You can see an illustration of what I'm talking about by going to searspartsdirect.com and entering your model number. If you look under the "Burner,Valve" heading on the next page, the igniter is listed as item 74. Let me know what you find.
Posted on Dec 17, 2008
Not reaching max heat
follow this test and fix it. Merry Christmas.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-1#ixzz2nvDsUQBK
Dec 19, 2013 | Whirlpool GGQ9800L Gas Dryer
Heat starts and then dies and never goes back on but dryer keeps spinning
follow this steps and fix it. God bless you
2. Heating element
3. Thermal fuse
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gV3bBWAa
Oct 01, 2013 | Whirlpool LGR6611L Gas Dryer
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 | Dryers
How do I get to my heating coils in my whirlpool dyer model WED550SQ0, from the back or the top
The heating circuitry for this model dryer is located in the rear of the dryer. Simply unplug the dryer and remove the exhaust vent hose. Loosen all the screws around the perimeter of the rear panel and remove. The heating element will be located on the right hand side inside the heater box. On the outside of the heater box will be two components, the Thermal Cut-Out (TCO) and the Hi-Limit Thermostat. The TCO will be located on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. These two components work in conjunction to regulate the temperature of the heating element. Both these components should read 0 ohms if good. If one of these components goes bad, you must replace BOTH of them at the same time (replacement kit part number 279816). Failure to do so can result in premature failure of any parts you replace. The heating element will read 9 to 13 ohms if good. The reason I mention this is because many people assume they have a bad heating element if the dryer does not heat. In the majority of the situations, however, it turns out to be a bad TCO.
NOTE: Make sure you take all resistance checks with the dryer unplugged and the components leads disconnected to isolate from any paralllel resistance paths.
If you have any questions, please let me know. I hope this helps you. For more information, you can refer to this link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you've already determined you have a defective heating element, that is great. I just wanted to include this information just in case.
Oct 07, 2009 | Dryers
Dryer stopped heating
OK, there are two likely scenarios, depending on whether your dryer is electric or gas. If it is an electric dryer, an open heater element is the most likely cause (change left in pockets is notorious for blowing out heating elements).
If your dryer is gas, the most likely cause is an open ignitor. Whirlpool, GE, and several other makes use a resistor type of ignitor which will burn open with time. It's an easy fix, easy to get to and readily available at most appliance parts stores.
Jul 13, 2009 | Whirlpool Dryers
Just quit drying clothes
If it does not dry them all then the element is a good guess or the thermostat.
If it dries them but not all the way check that the moisture sensor is not turned down too far.
The following should help you.
How to Repair Heating Elements A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Troubleshooting the Gas Heater
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
©2006 Publications International, Ltd.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Servicing the Electric Heating Elements
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
The heater may also malfunction because it's grounded. To test for this, set the VOM to the RX1 scale and remove the leads to the heater. Clip one probe of the VOM to a heater terminal and touch the other probe to the heater housing. The meter needle should jump to a fairly high reading. If the needle flicks back and forth at a low reading, the heater is probably grounded and should be replaced. Here's how to replace the heater:
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.
Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
Servicing the Fan
The most common dryer fan problem is lint clogging the air passages through the heater and through the dryer drum. To clear a clogged air passage, remove the back service panel of the dryer and back out the screws holding the air duct in place. Then reach into the duct and remove all the lint and dirt possible. Reassemble the parts.
Also inspect the fan for a loose screw connection where the motor shaft is set on the dryer's drum. Remove the back service panel, tighten the screw, and replace the panel.
May 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer
I apologize for taking so long getting back to you on this. Have you verified everything? The following link provides some helpful information on how to troubleshoot common ELECTRIC dryer problems:
http://www.fixya.com/support/r385301-thorough_dryer_advice
The component you mention, sounds like an operating thermostat, but I'm not sure. From the readings you provided, it sounds like it may be good. That's why I suggested the link in order for you to double check all your readings and symptoms. I'm not trying to undermine you technical abilities, but you may have overlooked something.
A model number would be a great help in understanding how your dryer is configured. You also never mentioned if this was an electric or gas dryer. I'm assuming we're talking about an electric dryer.
If this is a GAS dryer, the common source of a no heat problem is a bad igniter or gas safety valve coils. Please let me know which dryer type you have. I hope all this information helps you.
PS I failed to mention (I think) in the link I provided that there is also a centrifugal switch on the drive motor that (if faulty) will not enable the heating circuits. Double check everything else before looking into this option.
Aug 24, 2008 | Dryers
Kenmore gas dryer 110.97566200 gas dryer is running throught the cycle but no heat.
Your Heating Elements could have problemA dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Aug 04, 2008 | Kenmore 63942 Dryer
Not heating
excuse me i didn't notice the gas part most common is the ligniteri think i need a break
Apr 01, 2008 | Kenmore 72982 Gas Dryer
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
117 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
