Question about Audiovox D1210 Portable DVD Player with Screen
Audio yes, picture no!
I have an Audiovox D1210 TV/DVD that we have plugged into our cable in the house. We have not moved it in months! This a.m. was watching the news and turned it off. Came back later and no picture, just aqua blue screen, but can hear the TV shows. Cable is firmly plugged in as well as the electrical plug. Any suggestions?
    President:
  • 814 Answers
You can try to reset the DVD player to factory setting. Go to the set up main page. Highlight preferences and press enter. Go to the defaults setting and press enter. This will reset the DVD player to the original factory settings. If this does not solve you problem you can call the Audiovox customer support telephone number. 1-800-645-4994 Give them the model number of your DVD player and tell them the problem you are having with it. They will be able to tell you how you can obtain service for your problem. I hope this information helps you with your problem.
Posted on May 30, 2009
Why do i have a white screen on d1210 portable dvd player
That will be the screen driver chip faulty or even the luminance set too high. Try turning the brightness down and if there's a dark picture it's the chip, if not maybe even the flexi strip from the base to screen.
Jul 24, 2014 | Audiovox D1210 Portable DVD Player with...
What kind of external antenna do you use and where do you connect it?
Hello
It is best to use a yagi antenna. It is highly directional, but if direction is in right way, it will give you best clarity picture. The signal strength will be greater than other type of antennas. OK.
May 22, 2011 | Audiovox D1210 Portable DVD Player with...
I have a JVC DVD Player & VCR Model HR-XVC27U. It is hooked up to a Panasonic TV CT-32SL14J. I have Cable. With the JVC, I have lost any audio. If I record a VHS, I get picture, no audio. If I...
Shifting a heavy item, or anything really, can cause damage to either the cable or the port the cable is plugged into very easily.
I recommend replacing the audio cable, or trying an alternate audio output (you may be able to choose between RCA-style stereo audio output, digital PCM and digital optical.)
Similarly, the dvd player may be setup to output audio in a format that isn't matching what your AV receiver is expecting - again a variation of either stereo, digital rca or digital optical.
I hope that helps.
Jul 18, 2010 | JVC HR-XVC27U DVD Player/VCR
Need(lost)a fuse for car power cord for a audiovox D1210 want size is it?
TV/DVD combination unit
1 Left speaker
1 Right speaker
2 Pair of infrared headphones
Wireless remote control
6 "AAA" batteries
ADS-1225PC AC power adapter with attached 6' cord (12 V/2.5 A)
69" Power cord with cigarette lighter adapter (has installed 5A fuse)
7" RCA cable (has left and right RCA audio jacks and an RCA composite video jack on one end and a minijack connector on the other end)
1 Adjustable shoulder strap (has a maximum length of 47")
4 Adjustable mounting straps (each strap has a maximum length of 3')
One 90-degree coaxial adapter (has a 75-ohm coaxial jack on one end and a slip-on 75-ohm coaxial connector on the other end)
1 Storage bag
1 Mounting bag
Operating Instructions
Product Registration card
Dec 30, 2009 | Audiovox Televison & Video
Sony LCD TV has Dark Picture
the problem is not the lamp.
This model has a set of two backlight lamps, and it is practically impossible that both lamps go faulty at the same time.
When the backlight lap in an LCD TV goes off in this way, the faulty part is always the backlight inverter, that is the high voltage board powering the lamp.
In your case you have to get the TV inverter booard replaced.
May 30, 2009 | Audiovox D1210 Portable DVD Player with...
Just a really dark screen on all functions
If you are still under warranty try calling audiovox customer support at this telephone number 1-800-645-4994. Give them the model number of you dvd player and tell them the problem you are having with the dark screen. If you are not under warranty, You can still call them and ask them where to get service for bad power inverter or a bad back light problem. If they cannot help you you can go to this website http://www.lcdparts.net/Default.aspx They do all kinds of LCD repairs and also have a technical help telephone number. 1-877-870-0581. Give them a call and tell them the name of your dvd player and the model number and see if they can help you get repair service for it. I hope this information will help you with your problem.
Audiovox pvd80 region problem
Audiovox code hack For DVD player D1210
1. power on
2. SETUP
3. in setup digit 9653
4. go to new menu VERSION
5. in region use UP/DOWN to change region
6. power off and power on
7. Enjoy!!!
Mar 31, 2009 | Audiovox D1210 Portable DVD Player with...
Screen wont light
Are you still under warranty with this product? Have you tried to reset the DVD Player to the factory settings. You can do this by opening up the menu and on the main page highlight preferences and press enter.Now go to the default setting and highlight it and press enter. This will reset the DVD player to the original settings.If this doe not solve your problem you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them the problems you are having. They will be able to tell you how to get the unit serviced. I hope this information helps you with your problem.
Mar 24, 2009 | Audiovox D1210 Portable DVD Player with...
Audiovox d1210
We bought this player almost 5 years ago, and have the same problem. When we called audiovox at the time they told us that it was because some of the dvd mnufacturers had changed the format/technology in which they recorded the dvd programs. The biggest problem was with the Disney dvd's. Also, that they did not have any software upgrades at that time to upgrade the player. We used it for a while with the hit and miss movies that it would play, and then finally shelved it and bought a minivan with a preinstalled dvd player. Very rarely use the audiovox now. I am surprised; however, that after 5 years they would still have the same problem and have still not yet upgraded the software in this player. Good luck.
Nov 10, 2007 | Audiovox D1210 Portable DVD Player with...
Audiovox D1210 Portable DVD Player with Screen Logo
145 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
