Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
Yamaha EF1000 Will only idle and produce 12VAC
Hi, I have a EF1000 that the plug was pulled under load. Now the generator will only idle "Won't come up to normal speed" and produces 12 VAC. Any suggestions out there??
  • 4 Answers
My guess would be that some failsafe is in action here. It is possible that either a fuse OR the breaker is bad, or is not resetting in the case of the breaker button. Yamaha likes to idiot proof these things. Some of them disable the sparkplug if the oil gets low. Forget about just a warning light.
Posted on Dec 06, 2009
I have a EF24000is yamaha that stalls when a load is put on it
Hi, Raimo and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
EF1000is stalling
Honda generator won run under load
http://www.yamahamotorsports.com/assets/service/manuals/0/LIT-19626-01-23_1423.pdf
2009 Yamaha EF2000IS EF2000IS OEM Parts
Dec 29, 2016 | Yamaha Motorcycles
Yamaha ef1000 genarator,runs finds ,but when 120v load is added it goes dead
Loses power under load... could be a dirty air filter, or carbuartor need to be disassembled and soaked in gumout carb cleaner
Oct 12, 2014 | Motorcycles
Yamaha EF4500Ise Gennerator won't produce power.
Doe's it have a thermal couple on it? If so it could be bad and when it heats up it is killing your power.
Sep 18, 2012 | Yamaha EF4500iSE Generator 4500 Watt...
Yamaha ef1000 will start then push choke in and generator stops
clean tank fuel lines air filter and completely clean all carb parts and jets just did mine runs mint now did the same thing i also put in a new spark plug changed the oil a good once over goes a long way just take your time use a good carb cleaner like crc or gumout and check the jets they have small holes on the sides that can clog up hope this helps
May 07, 2012 | Yamaha 1,000 Watt Portable Generator...
Generator EF1000 manual
A consumer guide to Yahama's Premium EF1000 with specs, pictures, reviews, and manuals to download. www.poweredgenerators.com www.poweredgenerators.com/yamaha/premium-ef1000.html
hope this will help you
Jan 31, 2012 | Electrical Supplies
My EF2400iS surges under low loads. Seems to smooth out with larger load. Any suggestions? Throttle motor or control box?
Idle speed screw may need adjusting slightly to increase idle speed. Also Main jet and Idle mixture Screws may also be out of adjustment
Aug 23, 2010 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Running at idle speed
1) Check the "Economy Throttle" setting (or some similar verbage). Inverter types dont have to run full speed to produce full voltage.
2) Apply a load. These magically accellerate and decellerate according to load conditions.
Hope this helps,
Dolf-
Oct 13, 2009 | Yamaha 2500 Watt Industrial Inverter...
Oil change
Tip it over sideways - no drain hole exists, just the inlet.
Apr 01, 2009 | Yamaha Electrical Supplies
Coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
Feb 03, 2009 | Coleman Powermate Powermate 5000W...
Yamaha ef1000 will only idle and produce 12 vac
Hi, I have the same generator and I pull the load and it is fine. The engine RPM is controlled by the
governor. The voltage will not come up until the RPM is at full. First see what the RPM problem is and then check the voltage. Open the cover and look to see if the carb linkage is hooked up , if it is you mite have carb problem and address that first. Hope that helps.
Dec 17, 2008 | Yamaha 2500 Watt Industrial Inverter...
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
665 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
