Question about Toshiba 42H81 42" Rear Projection Television
Toshiba 42H81 Hyper Module replacement
I was wondering if a hyper module board MVPU14 with a 23599310c board will work with my 42H81 set that currently has a fubarred MVPU13 23599087b board. Does anyone know if these will cross match, or is the MVPU14 board not a compatible board for this tv? Thanks
MVPU14 and MVPU13 do cross.
Posted on Jan 02, 2009
Picture of hyper module board toshiba 57h84
Toshiba or any authorized service center can pull up the photo of that board (the 10 caps that fail are all indicated with red arrows) you are aware they are surface mounted caps?
Oct 28, 2012 | Toshiba 50H82 50" Rear Projection...
Toshiba hyper module. Vertical lines on screen.
change the 10 or so surface mounted bad filter caps in the Hyper module this set uses--the board is no longer available--it can be sent out for rebuild (not toshiba) but that is rather costly (200+)
Oct 28, 2012 | Toshiba 57H81 57" Rear Projection...
Toshiba/ 42H81 / hyper board
You can either yrplace your Hyper board, or replace all the serfice mount capacitors in it. The cap replacement fixes this 90% of the time.
May 09, 2012 | Toshiba 42H81 42" Rear Projection...
Picture is distorted keeps on moving
Good Day,
You have problem with caps on the Hyper Board. This is how to repair it:
MVPU13 Hyper Module Repair (23786198 / 23148017X)
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove
the top shield and replace all of the 10uf, 16v capacitors using Part Number 24619040 It’s recommended that all of the capacitors identified be replaced. (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care).
GOOD luck, big IRISH.
should be taken to avoid damaging the PCB while replacing these capacitors.
Dec 08, 2009 | Toshiba 42H81 42" Rear Projection...
The picture is all waves ,I get sound and color but the picture is all lines and waves,what part should I get??
To fix the shaky picture on the toshiba rear projection tv model number 42h83. You need to either replace the 13 capictors on the hyper module or simply replace the hyper module itself. It's cheaper to replace the caps, but you'll need decent soldering skills to do this. You can replace the entire hyper module with less soldering skills, but I believe the module costs about $100, maybe alittle more. You can find the entire fix by googleing "hyper module". Good luck and I hope this helps
Oct 21, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H81 Hyperboard
Tom,
I'll send the svc manual directly following this post, but as a word of caution be EXTREMELY careful removing the smd caps. You can easily damage the traces and make the module useless.
Bill
Nov 04, 2008 | Toshiba 42H81 42" Rear Projection...
No image on my TV
Bad hyper module = no longer available = have qualified tech
rebuild yours = replace bad caps on board...............T.
Dec 08, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
630 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
