Question about Mitsubishi VS-55707 TV
TV turns off on its own
My VS-55707 TV also seems to turn off on its own and stays off for a period of time ten to thirty Minutes before it will stay on. Is it over heating somehow??
  • Anonymous Jan 27, 2009
    same thing it turns on and shuts down
  • Mitsubishi Master
  • 5,138 Answers
Set may have poor/cold solder connections on power supply board and convergence board.
Posted on Dec 19, 2008
I changed the battery in my Saturn Vue 2004 my car starts but won't stay started
If it dies after about 2 seconds, do a reset for the key. Turn it on for ten minutes, off for thirty seconds. There a relearn procedure also. It is three times this, start after the third time. Have a battery charger on it.
Nov 13, 2016 | Saturn Cars & Trucks
How do I know if passlock is locked on my 2002 gmc truck
Security light will stay on or it will flash. A reset is turn the key on for ten minutes, turn it off for thirty seconds. try to start. Relearn is three times this. Try to start after the third time.
Oct 31, 2014 | Cars & Trucks
2000 Cavalier Z24 2.4 cranks but won't start. If i spray carb cleaner in the intake it starts but won't stay started. I have replaced the fuel pump,fuel filter. cam sensor &crank sensor. What else
It could be the fuel pressure regulator. OR maybe the security is set. Does the security light stay on or flash? If so. Turn the ignition on for ten minutes, turn off for thirty seconds. Then try to start. There is also a relearn for the security. Do the first, three times, then start.
Aug 26, 2014 | Chevrolet Chevy Cars & Trucks
I was plating for thirty minutes.i turn it off.when I turn it back on screen stays white.
LCD is bad. Period. Nothing you can do short of having it repaired / replaced.
May 19, 2010 | Nintendo DS Lite Console
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
TV Shuts Down
you may have vertical intermitance resold vertical ic or check connector to deflection yoke some time is intermiten..
Mar 23, 2008 | Mitsubishi VS-55707 TV
I have a VS 55707 . Remote will not keep system turned on
the problem is in your power supply there are small caps electrolityc capacitor that may be dry if you have esr meter check them and replace is around voltage regulator check for 25mfd at 200 volts or 4.7 mfd ..
Mar 17, 2008 | Mitsubishi VS-55707 TV
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
Set will not stay on
Better get this checked out by a technican. One possible reason could be coolant from the picture tubes leaking down onto the printed circuit board causing this symptom which could end up destroying the circuit traces on that board. Other possibilities include problems in the power supply or deflection circuits. If the set is over 8 years old, I would just replace it with a HDTV.
Jan 30, 2007 | Mitsubishi VS-55707 TV
Mitsubishi VS-55707 TV Logo
146 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
