Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
Yamaha ef1000 will only idle and produce 12 vac
Hi, I have a ef1000 generator and the plug was pulled while under load. Now the generator won't come up to speed, will only idle and produces 12vac.. Any suggestions out there??
  • Anonymous Mar 13, 2014
    After changing oil the oil light comes on and I can't get anything to happen after that. It was working great up until I changed the oil. I have checked oil level and ok there
Hi, I have the same generator and I pull the load and it is fine. The engine RPM is controlled by the
governor. The voltage will not come up until the RPM is at full. First see what the RPM problem is and then check the voltage. Open the cover and look to see if the carb linkage is hooked up , if it is you mite have carb problem and address that first. Hope that helps.
Posted on Dec 19, 2008
2 Suggested Answers
Last_Lion
  • 4 Answers
SOURCE: Yamaha EF1000 Will only idle and produce 12VAC
My guess would be that some failsafe is in action here. It is possible that either a fuse OR the breaker is bad, or is not resetting in the case of the breaker button. Yamaha likes to idiot proof these things. Some of them disable the sparkplug if the oil gets low. Forget about just a warning light.
Posted on Dec 06, 2009
I have a EF24000is yamaha that stalls when a load is put on it
Hi, Raimo and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
EF1000is stalling
Honda generator won run under load
http://www.yamahamotorsports.com/assets/service/manuals/0/LIT-19626-01-23_1423.pdf
2009 Yamaha EF2000IS EF2000IS OEM Parts
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 29, 2016 | Yamaha Motorcycles
Yamaha EF4500Ise Gennerator won't produce power.
Doe's it have a thermal couple on it? If so it could be bad and when it heats up it is killing your power.
Sep 18, 2012 | Yamaha EF4500iSE Generator 4500 Watt...
Generator EF1000 manual
A consumer guide to Yahama's Premium EF1000 with specs, pictures, reviews, and manuals to download. www.poweredgenerators.com www.poweredgenerators.com/yamaha/premium-ef1000.html
hope this will help you
Jan 31, 2012 | Electrical Supplies
7 hp brigs engine on my generator runs two fast producing 127 volts. how do I slow it down?
Hi and welcome to FixYa. I am Kelly. Since you did not mention the make or model number of your generator I will respond in generic terms. If your generator is at 127 volts with NO load it is adjust at the very top end of the manufacturers limits. There is a 10% tolerance so 120 VAC + 12 is 127 VAC. Under an electrical load above 500 watts the generator should drop the output voltage slightly so your generator would still be within factory limits. Personally on any generator as a repair person; I set the output voltage at 126 VAC no load so that when the user puts the generator to work the output voltage is good. If your generator is running at 127 VAC under load then you can adjust the governor screw on the governor plate CCW about 1/2 turn to drop the voltage. Without a generator model number or engine number I can not tell you exactly where the governor plate is on your engine / generator. The screw will have a lock nut that you must loosen 1/4 turn then turn the adjustment screw CCW to drop the voltage. Just make sure to re-tighten the lock nut when the adjustments are complete. Mind you by decreasing the output voltage you also drop the output freqency at the same time you decrease the output voltage. It is better to have 125 -127 VAC under a no load condition as the more electrical load you add the more voltage drop you will notice. It is best to adjust the generator to 122.5 -123 VAC under a medium load. (50% of output capacity) A bread toaster is 1400 - 1600 watts and is a good load for a 3000 watt generator. Also a good hand held hair dryer will use around 1600 watts. If you use this type of load and the voltage output is 122.5 to 123 VAC I would not adjust anything. I have been working on generators since 1970 so this is nothing new for me. I hope that you understand everything I posted. If not, feel free to ask as many questions as you wish in any future response.
Thanks for choosing FixYa,
Kelly
Jan 08, 2011 | Craftsman Electrical Supplies
My EF2400iS surges under low loads. Seems to smooth out with larger load. Any suggestions? Throttle motor or control box?
Idle speed screw may need adjusting slightly to increase idle speed. Also Main jet and Idle mixture Screws may also be out of adjustment
Aug 23, 2010 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Running at idle speed
1) Check the "Economy Throttle" setting (or some similar verbage). Inverter types dont have to run full speed to produce full voltage.
2) Apply a load. These magically accellerate and decellerate according to load conditions.
Hope this helps,
Dolf-
Oct 13, 2009 | Yamaha 2500 Watt Industrial Inverter...
Oil change
Tip it over sideways - no drain hole exists, just the inlet.
Apr 01, 2009 | Yamaha Electrical Supplies
Coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
Feb 03, 2009 | Coleman Powermate Powermate 5000W...
Dec 17, 2008 | Yamaha 2500 Watt Industrial Inverter...
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
862 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
