Question about Philips Magnavox DVD/VCR Dual Player
"Finalize Error" Sony DVDirect VRD-VC20
Sure hope someone has a solution to a real problem with the Sony DVDirect, VRD-VC20 writer. I purchased this about a year ago from Best Buy. It worked fine until recently, when I tried copying home movies and pre-recorded programs on the digital cable box. I have done nothing different, other than load a clean DVD into the machine. When it is finalizing the disk, it keeps giving a "finalize error" message and ejects the disk. I've been using the same DVD's that I had been using in the past (which worked fine), but I'm totally clueless to what's going on... If anyone has an idea how to solve this, I'd really, really, appreciate it. I DID upgrade the firmware about one month after buying it, and had success with the 16x DVD's. Have a pile of disks that are worthless, and am about ready to give this device the heave-ho. The reviews on Epinions.com were not very kind... Sincerely, Dave I have a DVD recorded off live TV that didn't finish writing the index when the recording finished. Now it show this as an empty title. How can I view these 3 hours that were recorded. The DVD recorder said "Disc Error" about 5 minutes before the show ended.
djnick989
  • 1067 Answers
SOURCE: dis did not finalize
bad dvd what brand uuseing to burn with philps is touchy are u addingto much to a dvd also i would do mor ethen 4 gb on a dvd 5 disk ok single layer burn it slow does it have a speed adjustment do 4x 8x max
Posted on Jan 07, 2008
SOURCE: Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Posted on Feb 10, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Posted on Feb 15, 2009
AJIN G
  • 6694 Answers
SOURCE: recently my Magnavox H2080MW8 HDD/DVD recorder
hi,
Error 25 by it means copy prohibited program. You can Try one thing, if there is any S-video out in your cable box or in your tv, then connect the S video out to the S-video input of the Recorder.Also connect the audio out of cabe box or the audio out of your tv to recorder, becuse S-video contains only Video information.
ok
Posted on Jul 18, 2011
donaldnegri
Same problem affecting both my Toshiba and Magnavox recorders. Began about a month ago and concerns my Comcast channels 703-714 (and their non-HD counterparts)....this is the 4 major networks plus PBS.....On Toshiba Forum, found 3 recent posts with same problem, and all mentioned Comcast. Comcast told me they have no idea......but I'm sure they're the culprit.
Posted on Nov 15, 2013
I need to have access to the manual for the sony vrd-vc20
Hi and welcome to FixYa,
Initially, try here. You would need Adobe Acrobat Reader to view this file.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 18, 2009 | Sony DVDirect (VRDVC20) DVD±RW Dual...
I NEED A SOFEWARE FOR SONY DVD WRITER (VRD-VC20) BRAND
I have never use with computer. have connected to VCR and small television, and copy direct from vcr to VRDVC20 and have had no problems. I do have the soft ware disc, as bought mine new and have used only to copy video to CD and if follow directions exact, the will finalize - no problems.
solargiant3@earthlink.net
Dec 01, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
SONY VRD VC20
Go to Nero.com the company which made the software for the device and you can download it from there. That is what I did. You need to up grade from what came with the unit.
Nov 25, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Creating DVD from VHS no sound on DVD.
Make sure the sound (red and white) connecters are plugged in and out from tv or vcr to in on recorder. I have four of these units and have had no trouble.
Nov 07, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Sony vrd-vc20
a code 10 error refers to a hardware failure, where the dvd cannot be communicated with due to it being faulty.
Aug 17, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
My vrd-vc20 do'not eject my disk
if your writer is showing in My Computer as a removable drive, you should bea able to right click on the drive icon and select Eject, but the programme you are using to burn must not be set to eject after finalising the disc in the preferences or settings.
Jun 20, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
I had similar problem (I have same model of Sony) on my dvr trying to record some movies, in my case it would start recording for a sec and then it would stop, problem in my case is that some of channels on satelite are scrambled and id doesn't allow even that they were stored on my dvr to get them on dvd drive, you can get descrambler on ebay but I just gave up cause it's too much hassle. Maybe you have similar problem cause I don't know who is your tv provider. Does your drive work on pc??? If so probably it is protection that is messing with your finallazing! I hope you find this helpful! By the way check my problem if you have any idea how to solve it I would very appreciate it! Nick
Mar 06, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
"Failed to Record"
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Goodluck!
Jan 04, 2007 | Sony VRD-MC1 DVD RW Dual Layer Burner
Philips Magnavox DVD/VCR Dual Player Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
