Question about Nokia 3100
My own number from my old sim doesnt appear
I have my old sim but i forgot my own number.. my handset is n3100. how do i find my own number if it doesnt appear in my contact menu.
    Problem Solver:
  • 4 Answers
Ring a friends phone and you'll get it that way but make sure you have your phone set to show your number
Posted on Jan 09, 2009
Hi, could you tell me how to reset security codes of Nokia 5610? I forgot the codes. Tried default codes 12345, used master codes (that you get after entering the IMEI number) but nothing worked out yet....
he default Security code is 12345.
If you changed it and forgot the security code please contacts your device dealer. They will provide you the default security code so that you can use your phone.
This security lock prevents thieves from being able to make use of stolen handsets that is why it can only be unlocked by authorized device dealers.
Oct 04, 2011 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Resetting Security Code
you can reset your handset by dialling the no *#7370#..,please take the back up of your handset before doing that because it will delete all your data..than try if it doesnot work than you have to get your handset flashed from your handset dealer. hope this helps.
Nov 15, 2007 | Nokia 5300 Grey Cellular Phone
I forgot my phone password
this happens all the time with samsungs. i went to tmobile.com/forums and found some info to fix mine when i forgot mine as well lol. the problem is it will reset your password and all your other information as well :(
A phone lock or security code on most Samsung handsets can be overridden by performing a full reset on the device. This will set the security codes on the handset back to the default eight zero's (00000000).
Important: This reset restores the original factory settings and will erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). Make sure you have backed up contacts, calendar appointments, and other data before continuing.
1. Power off the handset
2. Remove the battery
3. Remove the SIM card
4. Reinsert battery ONLY
5. Turn handset on
6. At the Insert SIM prompt screen enter the following code: *2767*2878#
NOTE: If using a handset that was released after July 2009 use this code: *2767*3855#
7. The handset should display E2P custom reset
8. Power off handset
9. Reinsert SIM card
10. Power on handset
11. The phone should be unlocked
NOTE: If you didn't get a E2P custom reset or a Full reset message on the handset your Samsung model may need an MCK code. You will have to call technical support for this code. Please have your IMEI number ready to expedite the process for this code. Your IMEI number is located on a label on the back of the phone,under the battery.
Dec 24, 2010 | Samsung C3510 Cell Phone
Handset locked/setting changed
new simcard doesnt support motorola old phone software ,,for that u need to upgrade your motorola mobile software..now jus visit any motorola sservice center and upgrade the mobile software..
Mar 23, 2010 | Motorola Mobility C118 Cellular Phone
All calls show up as 'unknown' on my t707a 9even if they're not private. How can I fix this?
Have you changed handsets recently if your phone book has been saved on the handset instead of your SIM when you change handsets the SIM will not have any numbers and contacted stored on it.
Put your SIM back into the old handset and copy all your contacts from the old handset to your SIM and reinsert it into you new handset.
It will take a few minutes also any messages that you have saved with your known contacts will also be updated.
Oct 13, 2009 | Sony Ericsson T707 Cell Phone
I forgot my personal code.
contact ur carrier and u would be provided with the PUK code ...
If PUK code doesnt work use the pin code of the sim card
if u hace forgot ur password nothing can be done neither u can take backup nor u can retain data in handset. U will have 10 chances at the max to enter correct password, if done with it the handset will be wiped out.
May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Security code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a "new" sim if the phone security code is entered.
Which is the one that you want?
The IMEI (International Mobile Equipment Identity) number is required to Unlock from a network. Type *#06# to get the IMEI number.
Also needed to unlock from a network is the Network name or code and the country it's locked in.
Mar 11, 2008 | Nokia N70 Cellular Phone
Forgot security code
i forgot my phone security code.my cell is 3310.can any one help me pls!! my imei no. 351106105391536
Mar 10, 2008 | Nokia 6600
Forgot my lock code for N73
you need to have a master reset code to reset all the settings. I do have an unlocker for this. if you want just give me the IMEI code and I could process it for you FREE.
Feb 26, 2008 | Nokia N73 Cellular Phone
Voice command
chk ur handset settings.chk whether audio message is enabled or not?..orelse try by restoring handset and then reinsert sim....
Oct 23, 2007 | Nokia 6030 Cellular Phone
Nokia 3100 Logo
131 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
