Question about Canon MV630i Mini DV Digital Camcorder
Wont work on battery power
Records and plays on charger power but doesn't work at all on battery power. Batteries OK. It worked fine yesterday! Put it on charge last night and it's not working today.
Have the same problem. Did not find any solution yet. Looking forward to someone who can help. Might be electronic.
Posted on Oct 22, 2010
Hi is it not powering up at all? i have the same problem here!
if you found the answer, please put it over here!
Posted on Feb 20, 2010
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
My jazzy is used but i bought new batteries for it but the key pad will only cut on when the charger is attached. and wont cut on at all with out the charger.
super hmmm new batteries? well I would check the battery connections because you should be getting power to the joystick. The charger is providing power thru your joystick to be able to turn it on. Now when you plug in the charger are you getting any movement on the meter at the rear of the chair? If not but staying at zero then the charger is not charging the batteries and your batteries are not hooked up correctly. You will have to remove the seat and cover over the base to have access to the batteries check all the connections and make sure that if the plugs are colored that the red and white plug is plugged into the red and white plug going to the front of the chair and that the black and white plug is plugged into the black and white plug going to the front of the chair. If the wiring is ok then get a meter and read the voltage across each battery they should read 13+ volts fully charged. Plug in the charger and read the voltage at the batteries again if charging then you should read 16+ volts. If the voltage doesn't change then the charger isn't working correctly and if reading a good voltage then the batteries are bad and need to be replaced. Hope this helps
Apr 17, 2011 | Pride Jazzy Select 6 Indoor Power...
Had new batteries and a service 6 months ago. Has now been left standing for a couple of months. I charged it up last night, but nothing. The charger appears to be working, lights working. Any ideas
Yes your batteries have dropped below 9 vlt each and they wont chage using your charger. Yuo must take a car battery charger and charge each battery up to at least 11vlts for your charger to charge! This ought to work if batteries have only been sitting a couple of mths . When using a car charger set charge at 6-10 amps for about 45mins to 1hr then hook up chair charger and you should be ok
Feb 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Phone won't charge
check charger pins and charger socket and its contacts and the fue in the board. if anyone fails in this charger wont work.
Feb 06, 2009 | Sony Ericsson W660i Mobile Phone
Works off mains and battery but wont charge battery.
replaced the circuit board where it meets the battery
Aug 20, 2008 | Dewalt DC011 AM/FM Radio
Canon MV630i Mini DV Digital Camcorder Logo
46 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
