Question about LG LRFD25850 French Door Refrigerator
Ice machine the ice machine makes so much ice that every time I open the drawer to get some it falls all over the floor. any help ideas
  • Anonymous Nov 04, 2007
    Yep, I have the same problem. I actually called within the warranty period about this problem, and the solution was to give me a bigger ice bucket - what a joke!!! The ice maker does stop making, but the ice is piled too high, so that when you slide the drawer out, the top layer of ice is knocked into the back of the freezer drawer.
    Champion:
  • 210 Answers
The other thing you can do is use the on off switch. Your ice only lasts so long before it starts to absorb all the odours from other food in the freezer and or gets freezer burn. Why not just turn it off when it gets full and then empty out the bucket once a month and make fresh ice.
My sources tell me they are working on a new ice bucket that will solve the problem once and for all. Might be out in the fall.
Sgt 48
Posted on May 31, 2008
  • 489 Answers
There is an update for this problem.  The icemaker sensor arm is too short and an updated version is now available.  You will only need the sensor arm.  The part # is MFC39559901.  The arm replaces the old arm and works really well.
Posted on Apr 29, 2008
Water falls into ice tray and freezers.
If you have a Samsung French Door (as I did) you'll find the solution here: Samsung Refrigerator Leaking Into Crisper Drawer Floor
Mar 23, 2016 | Refrigerators
Hi, freezer makes too much ice. We have to continually empty the drawer when it is full or no ice will come out. And when we do, ice falls to the floor.
GE has a new bail arm that will correct this issue, check with your local part house, this part is under 20 buck and will correct this issue for you.
I hope this helps, get me the complete model number and I can research this and get you the part number if you like.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 13, 2013 | GE PSS25MGN Side by Side Refrigerator
Ice falls out of drawer when open up
if its a no frost refigerator sounds like you might have to take all the drwars out unscrew or detach the back plate and defrost the fridge manually and then unblock the drain hole which goes to the back of the fridge into a plastick container ontop of the compressor which in turn will evaporate from the heat of the compressor . Hope this does the trick
Apr 30, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice falls to bottom of frig when drawer is opened
If when your ice bin is pulled out it drags ice cubes from top of bin as I understand I would think that the sensor that tells the ice maker is not responding correctly. As I remember your model a PSS26MSRSS Profile/Artica has electronic Ice Makers that I hate and I think most people will agree that anything on a refrigerator electronic is a big mistake. All refrigerators have their problems but the electronic controlled models have so many complaints! Now I also noticed you did not confirm your model number so I need to ask is your model the PSS26MSRSS Profile? This is a lot of writing if I happen to be quoting a different model than yours, Thanks Sea Breeze
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice is jamming on external dispenser. open the door and ice falls all over floor. what could it be?
my freezer is leaking water all over the floor it can come ok for a few days then starts again also build up of ice inside freezer any ideas how to solve this??
Sep 09, 2009 | LG Refrigerators
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Feb 08, 2009 | LG LRFC25750 Refrigerator French Door
Ice maker tray
There is a fix for this problem.  Call a qualified LG tech to order the updated metal bar for this icemaker.
Feb 02, 2008 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG LRFD25850 French Door Refrigerator Logo
153 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
