Question about Compaq Presario Notebook
Unmountable boot voulme in windows xp
Needed to shut it down when it was locked up--now I can no longer bring it back up, i have tried inserting the recovery cd--it does not seem to be recognizing it--i have changed my settings in the start up so I think i should be booting from there first
  • 2 more comments
  • Sally Corbett Dec 17, 2008
    I am using windows xp, and have a driver recovery cd in--i'm not sure if this is what you are asking--i am not real up on all the computer stuff--but i was hoping i could weigh through this with some help
    No--i can go to f8 and try to boot up in the safe mode but all i get is the following multi(0)disk(0)rdisk(partition(1)\windowssystem32\ with various files after that--i cannot get to a prompt to try to check or repair disk
  • zonkpc
    zonkpc May 11, 2010
    Can you boot into windows?
  • zonkpc
    zonkpc May 11, 2010
    Enter this disk management system in windows, the partition probably needs formatting.
  • 68 Answers
Unfortantly if you can not get the recovery to work a clean installis probably the easiest soloution
Posted on Dec 17, 2008
I am getting a blue scree error on my IBM Thinkpad R51 that says unmountable_Boot_Volume. It will not let me run on save mode...it brings me back to the blue scree error message. I have windows xp
Unmountable boot volume = The file system is damaged and cannot be mounted.
To fix that do the following:
1.Put the CD first in the boot order and boot from the XP install disk.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select your partition - it should be C
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Jun 14, 2010 | IBM ThinkPad R51 Notebook
Hi i have an acer aspire 3690 and cannot boot the pc as it says unmountable boot volume. i dont have the recovery cd or bios password as bought from someone i used to know in the uk and im no longer living...
Hello
Thank you for using
FixYa for your problem
If you receive the “unmountable boot volume” error and have an installation disk, you still have a chance to save your system.
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
If all went well, you should now be able to boot back into Windows without a problem!
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
Unmountable-boot_volume
Must have shut down the computer incorrectly or the power went out and changed the subroutines.Try to locate a windows cd and do a repair R just put cd in and restart computer when it asks to do a fresh install press repair.
Nov 11, 2009 | Intel Computers & Internet
Unmountable boot volume hp pavilion ze4400
Recommend entering Windows XP CD, and entering R once the CD Boots up, and enters installation mode.
This will bring you into the Admin panel, enter password, and than enter chkdsk c: -f Once this is completed eject CD, and than restart XP.
Jun 30, 2009 | HP Pavilion ze2000 Notebook
Error message: unmountable boot volumn
Yes you can save your computer. But if you are running Windows XP, you need the Windows XP CD. Boot with that CD and at the first prompt, press "r" to get to the repair option.
Press 1 to choose your windows instalaltion and then at the prompt, type the following
chkdsk /r
this might take some time but at the end, type the work exit and you should be back in business.
Mar 13, 2009 | Dell Dimension 4600 PC Desktop
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Unmountable Boot Volume
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Computer shut down ..wont restart
what has happened is your hard drive as failed and that is why it shut down and then gave the unmountable boot volume. You could try repairing windows using your XP cd but it's a new hard drive i recon.
Oct 05, 2007 | Compaq Presario M2000 Notebook
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
