Question about HP PSC 1315 All-In-One InkJet Printer
Paper jam is showing on printer info., but ther's no paper jam.
The copier will copy with no problem, but the paper jam prevents any printing from the computer. I pulled jammed paper out but can't get printer to reset.
    Problem Solver:
  • 7 Answers
Ok this issue ussually occurs when the roller feed doesn't load the paper due to the following reasons:
1. If your printer is operating for  more than two years or so... gear tear will most likely to occur. If you can open the printer and check everytime the printer initiates after power on ad if the roller feed doesn't rotate but the leftmost rotary gear with the encoder wheel rotates, the gear is most likely to be loose even there is no paper jam nor dust contamination on the rubber and paper feed mechanism. You need to replace the said gear with the encoder strip . A simple solution would be aplying epoxy resin so it will be fixed on the rotary shaft. It may last for quite sometime but better yet replace the gear.
2. The feeder rollers might be dirty and needs to be cleaned and greased the gears.
3. Probable defective print cartridge. Try replacing it with a new one.
But based on the items above, if your printer is operating more than a year or two, and frequent paper jam is being experienced, gear tear near the motor is the culprit.
Posted on Dec 24, 2008
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
You have a piece of paper stuck in one of the switches that tells the machine you have a paper jam. One of the worst things to cause these are printing peel off labels as they sometimes peel off while printing and get caught in the mechanim. You have a jam it's just not a full size piece.
Jun 01, 2009 | HP LaserJet 3030 All-In-One Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Printer malfunction
The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
Dec 19, 2007 | Samsung ML-2150 Laser Printer
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
HP PSC 1315 All-In-One InkJet Printer Logo
133 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
