Question about Car Audio & Video
Brake bypass for in dash dvd- DP432
DP Video DP432, how to bypass the brake on dvd hold, will disconnecting the pink wire resolve issue? Or need to use some kind of switch like mentioned in threads for another manufacturer?
  • ecoli8 Dec 20, 2008
    works thx!
  • 05neon Dec 26, 2008
    what if i connect it to the black ground wire behind the stereo, will that work...?
Dbd805 dp video deck how do you bypass the safety feature when you put the car in gear.
Posted on Feb 08, 2010
    Problem Solver:
  • 7 Answers
Connect the pink wire to the car's body ground
Posted on Dec 18, 2008
  • Glenn Santiago Jan 06, 2009
    yes you can.. the black wire is also the ground.. but I recomend that you use the body ground.ü
I have the dp video dbd805 dvd player and the subs keep fading out when i drive for like 2 mins,everything else still play but not the subs
Posted on Nov 15, 2014
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
How do I bypass wiring up the parking brake wire
wire a switch pink to one end and the other to ground when you flip the switch the radio thinks its a brake.
Nov 25, 2009 | JVC KW-AVX810 Car DVD Player
I lost user manual for Performance Teknique ICBM-9493TV Car Video
Yo I have a icbm 5254 in dash monitor and in order to bypass the parking brake security, splice the wire that's marked "park brake"(mine is Pink, yours may be Orange,but it'll be the oddball colors) into the acc or aux wire(usually yellow) and it'll play dvd while moving. Hope this has been helpful.
Feb 28, 2009 | Performance Teknique ICBM-9493TV Car Video...
Bypass parking brake for VR3
Hi, I had the same prob with mine. Pretty easy fixed. There is an earth wire connected to the park brake switch, you have to disconnect it. If you are not savvy with car stereo installation, I would advise you take it to strathfield or another car stereo installer - it is a quick and easy job and they shouldnt charge you more than 20 bucks for it.... if that. Beware though, playing movies in your field of view is VERY distracting and dangerous..... and illegal.
Jan 16, 2009 | Jensen VM9510 Car DVD Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Brake bypass code
I just got this same unit on thursday of last week and put it in myself. All you have to do is ground the pink wire out and it will work without having to put a bypass code in. Hope this works for you as well.
Mar 31, 2008 | Phase Linear UDV9010 Car DVD Player
Trying to find the parking brake
YOU DONT NEED TO HOOK THE PINK WIRE UP JUST PUT IN A DVD AND TYPE IN 543210. THIS IS A BYPASS CODE SO YOU CAN PLAY DVD WITHOUT HOOKING UP THE PINK WIRE. YOU MUST HOLD DOWN THE 0 FOR 4 SECONDS WHEN PUTTING IN THE CODE.
Jan 15, 2008 | Jensen VM9510 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
1,667 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
