Question about Channel Master (9537) Remote Control
Channel Master Model 9537 Died
Not usre what is wrong with my Rotator OCntroller but it won't turn on...and, yes we changed the batteries.
  • pwiesemes Jan 17, 2009
    1, 2,4,5,& 6 are the only working buttons. All others do not function.I have changed the batteries with no difference.
My 9537 lights up and goes thru the numbers 0-360 but the antenna does not movmove
Has this installation previously worked or is this a new installation?
Sounds like it may be in the rotator itself.
Dec 28, 2014 | Channel Master CM 9537 Antenna Rotator...
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
Dec 10, 2012 | Hitachi Clu-577tsi Remote Control
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
atdlee@netzero.com
Nov 17, 2012 | Canon Speedlite 580EX II TTL Flash
Is there a way that my 9537 control can be modified to connect to my computer so that my Amateur Radio program (Ham Radio Deluxe) will turn my rotor to the direction of the station I want to contact? Bill...
There is a software program call proximus that will allow you to control your IR receiver with the necessary remote codes for the 9537. it\'s a pain to figure out . but it does work. I use mine with Orbitron satellite tracking software to follow Ham radio satellites.
Jun 08, 2011 | Channel Master (9537) Remote Control
Unable to save pad and volume changes in the USR pattern ........ example, "Blues 5" attempted to change the snare from RingSnr1 093 to RatlSnr2 092...... plus pad volume from 97 to 85. While in...
Hi, am pretty sure the problem you are encountering is a " battery backup " issue. Any time you "save " a setting in a peice of electronics this is accomplished by way of some sort of memory ( powered by either a rechargable battery somewhere on the circuit board or what's know as a storage capacitor-set apart if not by it's looks then from its markings, Farads or F versus the standard Micro-Farads-Mf or pico farads,Pf. When this little device ( around $10 if capacitor vs. battery- little less) fails everything works normal except when you power off you lose your settings( or in your case switch patterns ). Thanks for asking FixYa, I hope this was of some help, Good luck,Prodzilla
Apr 13, 2011 | Audio Players & Recorders
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Oct 26, 2010 | Channel Master (9537) Remote Control
Hello, my name is Rick. My remote is not working, i unpluged the unit then pluged it back in. It displays 01 and will not respond to my remote
Dear Rick/
please cheek the following to find ouy if your remote is working
1 remove batties hold down one button on remote control for 30 sec fit new battiers and test
2 if you have a mw radio turn this to about 1,3Mhz hold remote control near radio ,pressing any button on the remote will be heard from the radio in the form of poping / ticking noise ,
3 another test would be to point the remote contrul towards a digital camer pressing a button will show a dot flash on ldc display
hope this will help regards derrick
Mar 14, 2010 | Channel Master (9537) Remote Control
Rotor not turning antenna
Most rotors have a brake, if yours has one, you have to hold the brake down then rotate.
Jan 31, 2009 | Channel Master 9521A Remote Control
Channel Master (9537) Remote Control Logo
132 people viewed this question
Top Channel Master Televison & Video Experts
Marvin
Marvin
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
