Question about Frigidaire PLD4375RFC Dishwasher
Frigidaire dishwasher door won't close
New model PLD4375RFC has latch in closed position while door is open -- can't close the door. We have read the manual and are pushing the right buttons in the right order. Advice, please.
  • gjthaler Feb 11, 2009
    my dishwasher door will not stay closed seems to post cl message when switching cycles
  • barkway May 11, 2010
    Our has the opposite problem: it THINKS the door is open when it is closed! And we can't start the dishwasher because it keeps blinking CL (close the door) when the door IS closed!
    President:
  • Frigidaire Master
  • 2,651 Answers
With aa small thin screwdriver you can try to pry the "latch/catch "back to an open positon
Posted on Dec 17, 2008
THE LATCH IS READING THAT THE DOOR IS CLOSED BUT I CAN OPEN THE DOOR WHILE THE DISHWASHER IS IN CYCLE. WITH THE SPRING INDISE THE DOOR BEING LOCKED IT WONT EVENT LET ME FULLY SHUT THE DOOR! ANY HELP.
Hello friend, thank you for your post!
From what you have described the spring from the latch is broken inside of the door and you are unable to close your Frigidaire dishwasher. You would need to disassemble the dishwasher in order to replace the latch or spring. This needs to be done by a professional technician as improper disassembly could results in personal injury. I hope this information is helpful to you. -Matt
Feb 19, 2016 | Frigidaire Dishwashers
So I close my car driver side door and it automatically says on the dash board that my door is open?? Any suggestions on what might be wrong. Its a 2011 Ford edge if that helps at all. thanks
Your door ajar system is tied into the door latch mechanism. if the door still appears to close tightly, and the door latch works properly, then you may need to adjust or replace the latch, though ford has listed a cleaning procedure for the latch that involves using a tool to test latch position and manually closing the latch (while door is OPEN) using a screwdriver 10-20x and monitoring to see if the latch consistently shows CLOSED and OPEN when it should.
If pushing the door closed after its already closed causes the lamp to turn off, an adjustment of the latch may help, or cleaning the latch contacts may also help. If the door never shows latched regardless of how hard it is pushed, it may be a defective latch, or a wiring problem (Door wires sometimes break in the door harness between the door and the side of the dashboard when the harness enters the vehicle).
Feb 24, 2015 | Ford Cars & Trucks
I have a Frigidaire dishwasher model # FDB2415LFSO with a blinking CL code. When I try the normal wash cycle button the drain pump runs and the CL light blinks continuously and nothing more happens. The...
Good Afternoon friend, thank you for your post!
Based off what you have described you have performed multiple tests to your Frigidaire dishwasher and it continues to display a "CL". That code does stand for close door which can mean that the door switch is sensing it is opened. For this error code it could be a possible problem with your door switch or main control. I understand you stated that the control did not appear to have a burn inside of it so it is easy to assume that the door latch could be the issue. Remember if you are not a professional technician this could be the start of unnecessary part purchases. I hope this information is helpful to some degree. -Matt
Feb 24, 2015 | Frigidaire Dishwashers
I have a 1994 BMW 325i and both of my rear doors won't close.. The latches just move freely. Any sujestions?
I didn't see the other posts but did you try to hold the door handle as to open the door and move the latch up so to open all the way. I have seen kids play and push the latch when the door is open and it latches it closed when the door is open and then the door won't latch because it's not on the bar to reset it in the right position, may want to try that.
May 23, 2014 | 2001 BMW 325
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
Kitchenaid dishwasher KUDS30IXBL door locked open, will not close
There should be a type of hook inside the hole where the door latches to the machine. Hold the handle up and rotate the hook latch so the open side is pointing towards the machine. The click you heard was the latch that holds the door closed moving to the closed position when the door was open, and it needs to be in the release position.
Jan 28, 2013 | KitchenAid KUDS30IXBL Builtin Dishwasher
Door latch not working on Frigidaire 18 in.
Hi -
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 21, 2012 | Frigidaire 18 in. FDR252RB Built-in...
Electrolux Dishwasher door won't close or latch shut
Contact a professional to replace the door switch or adjust it.
Aug 07, 2012 | Electrolux Dishwashers
Unable to close door
I have 2 different door problems with my 99 Park Ave: one door opens more than it should and often can't get it to move to close it and the other door opens but when trying to close it, the door will not latch closed. I'm not exactly sure what you mean by door wouldn't close, but with your mention of the metal parts, I'm gonna take a guess that it doesn't latch closed (kind of bounces back open too). For that problem I do 2 things to avoid actually fixing the problem. First, I check that the door handles are in the closed door position (my outside handle stays stuck out in the pulled position); I push them both in. If that doesn't work, I push down on the latch mechanism in the edge of the door to find that it was stuck in the open position. Once I do those 2 things, my door closes perfectly.
I hope this helped!
Jan 30, 2012 | 1999 Buick Park Avenue
Upper oven turn on and off then puts f9
F9 indicates a problem with the door latch circuit. Holding the door in the open position, push in the door switch until the cavity light goes off. Put the upper oven in the clean cycle and watch to see if the door latch cycles.
If the door latch mechanism is working correctly, the latch should stop in the closed position (the door will not shut all the way now). If the door latch does not even move and the F9 error appears, which is highly likely, you definitely have a problem with the latch circuit. (If the door latch did cycle to the closed position, cancel the self-clean mode to cycle the latch back to the open position.)
First, check that there are no loose wires on the door latch switches. Also check that none of the wires are pinched between the latch mechanism and the Oven Control Unit. Repair any wires that may be damaged and reconnect any connections that maybe loose. If you have just made any repairs, try putting the oven into bake mode with the door closed and test.
If there was no wiring that needed repaired and all connections looked good, test each of the door switches to be operating properly. Disconnect the wires from one switch at a time and perform a continuity test on the switch. In the open position your meter should read "OL", in the closed position it should emit a tone, or read "0.0". If either switch fails this test, replace the switch and test your oven again.
If none of the above conditions exist, the Oven Control is not reading input from the door latch sensor and needs to be replaced.
Apr 15, 2011 | Ovens
Frigidaire PLD4375RFC Dishwasher Logo
2,436 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
