Question about Refrigerators
I have a Frigidaire, plrs267za. The ice maker will not fill the tray with water. It runs thru its dump cycle then, I hear what sounds like the valve turn on to fill with water but, no water comes into the ice tray. Any suggestions?
  • 108 Answers
The filter is probably clogged. Turn off the water supply to the icemaker, disconnect it from icemaker and turn the supply valve on long enough to determine water is available. You say you hear the fill valve opening. The filter is the only problem remaining.
Ray
Posted on Dec 17, 2008
My Ice maker doesn't make ice anymore
90% of ice maker problems are water related. Sounds like water may be continually seeping in from the inlet water valve (normal thing to do if the water level is low). This will not allow the water to get down to freezing temperature. You have to identify the reason that water is constantly running in. It's probably "leaking" out at the dump valve. Or does that unit have a float valve that may be leaking. Check your drain to see if water is leaking out during the freeze cycle.
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Ice Maker fails on occasions to dump ice before water is dispensed
monitor the cycle as it is filling water does it over fill or is there a seepage that continue to drip, it could be the water valve. Also do you hear the tray making noise as it tries to dump the ice "the harvest cycle" try to watch it to see if it is a mechanical gearing problem
Nov 19, 2013 | Refrigerators
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Ice maker not working
Try filling the ice maker with tap water and let it freeze. If the ice maker cycles and dumps the cubes and then does not refill the dual water valve on rear of the refrigerator for the ice maker fill side is defective, if nothing happens when you pour the water in the trays then most likely the ice maker needs a new thermostat. I'll come back hopefully with photos and links. Sea Breeze
Oct 17, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
I have a side/side model KSRD25FW15. Can get water thru door but won't fill ice trays. Why won't ice trays fill?
That is most likely the water control valve on the rear of refrigerator and near the floor. If the ice maker is empty fill with tap water and let it freeze. If it dumps and does not refill the water control valve for the ice maker is defective. I will get back soon with the parts number. Thanks, Sea Breeze
Aug 17, 2009 | KitchenAid Refrigerators
Ice maker leaking
shut off the water going into the unit if it stops doing it then your valve is bad as it is leaking by and filling the im too much
May 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
286 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
