Question about Tappan 24 in. Freestanding Gas Range Kitchen Range
Burners well not light up right and pilot lite is real small
When i turn on the lf frt burner it well lite up but the flame is small then if i turn on the rt rear burn it well not lite up untill i turn off the lf frt burner then it well lite up i have check for gas leak but there is no leaks and the stve is the only thing doing this ever thing in house is working fine this stove is a mpf300pxwe how can i fix this thank you
  • 585 Answers
Two possibilities: This is a stove orificed for propane and connected to natural, or the regulator ( a squarish shaped thing in the line under the cooktop) has a problem and is limiting gas flow way below normal. In the first case you just got the stove, in the second it has worked fine until the sudden change.
Posted on Dec 17, 2008
I have an old gas stove. No igniter.Lights with pilot light only. Stove top burners work fine.Oven does not ignite. The pilot lite is on.I smell no gas when I turn it on.
Pilot flame has to hit the thermocouple. If pilot is dory flame.will be weak and not reaching the thermocouple that tells the oven there is a flame and opens the burner. If the pilot is strong and no gas to burner than that thermocouple. ( 100% safely valve is worn out) replace that and you are good
Dec 30, 2017 | Kitchen Ranges
Why does burners and pilot forced off after burners are engaged
We get asked this question many times.
If you light your pilot light, hold in the button and then when you release it and the pilot light goes out, generally you need a new thermocouple. Gas repairs can only be undertaken by a qualified gas technician so you can't do this job yourself.
The thermocouple is a safety device that recognises that the pilot has a good flame and is enough to ignite the main burners. The thermocouple open that valve to the burner.
In limited circumstances the thermocouple doesn't need replacing, either the shield that aims the flame to the thermocouple has become dislodged, or the pilot jet is a little blocked by debris. Either way, having the appliance serviced by a qualified gas fitter is the way to go. I am sure you will have seen news stories about explosions caused by gas leaks and faulty appliances.
Jan 18, 2016 | Procom Heating & Cooling
What is the flame sensor
The flame sensor is attached to the pilot light. It's down on the right side of the burner tray and usually has an orange wire attached.
The flame sensor lets the heater know that the pilot light has been lit and it's okay to open the main valve.
images?q=tbn:and9gcs_-csiy0xlxc4vgn5fxb5i4km7zxxkzfpham9qknrvchqj1v19hq
Mar 06, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot lites when I turn to on burner lites the pilot goes out flame drops down and goes out
Try cleaning the pilot out sounds like flame is too small and when main burne rlights it takes gas away from pilot .
Clean pilot try blowing it out with can of air or with air line carefully .
Feb 10, 2012 | Heating & Cooling
Pilot light goes out when gas turned on
I am assuming that you are saying that after you have pushed the pilot knob down and the pilot lites and stay lite and then you turn the knob to turn it to ON the pilot goes out...... Then the Gas Valve is bad and will have to be replaced....... Or if you are saying that the pilot goes out when the burners come on then you may need to replace the Thermocouple because the main burner flame is pulling the pilot flame off of the thermocouple and it is weak and will shut the gas off.... Or You could have a cracked heat exchanger that when the burners are on and then the blower comes ON and is blowing the flame around and blowing the pilot flame off of the thernocouple......which will shut the gas off....and then you will need a new furnace or New Heat Exchanger...... These are the most common problems Hope this helps.....
Feb 16, 2011 | Heating & Cooling
My pilot turns on but the burners never start up after I turn on the switch on my Teledyne 2 Pool Heater. Any suggestions on whether the burners may be clogged or defective or if it is the switcÉ
You have a bad flame sensor or a bad burner graound... the gas valve porves the flame by passing a very small current through the pilot flame... yes flame does conduct electric...if the sensor is dirty or bad or the ground wire to the burner is corroded the gas valve does not sense the current and "see" the flame.
heatman101
Aug 13, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Right stove top burners won't ignite
Your right side burners probably have small vertical lighting holes that are clogged where the pilot lights the burner. Use a sewing needle to poke each hole clean. While you're at it, poke clean the horizontal burner holes just to make sure they are not clogged either. Are there also little tunnels from the burners to each pilot flame? Make sure those are clean inside and attached properly on each end. The pilot flame should be approx 3/8" tall. Compare the working pilot flame to the non-working pilot flames and adjust as necessary. Each pilot has a small aluminum tubing running to it, the adjustment screw will be on this tube. You'll just need a small flat head screw driver to turn it counter-clockwise to increase flame. Hope this helps. Let us know if we can be of further assistance. Douglas
Jun 05, 2010 | Amana ACF3325 Gas Kitchen Range
I have a whirlpool gas range , it must be the cheapest one as it has no electrical connections,and I have no manual ,how do I light the pilot lite ????
There are actually two pilot lights to light, (maybe three) Under the top there would be the old style flash back tubes leading from two burners to a pilot. This small flame stays lit while the gas is on. When you turn a burner on some gas flows back through the tube and flashes or lilghts the burner.
When you turn the gas on there is always gas through the pilots, unless shut off with the little set screws if you follow the lines. From the factory these are on and open. Small set screws also adjust pilot flame size.
THe other pilot for the oven is down by the main burner. There is a small cap tube from the gas valve to a holder just under the burner. This is where it is lit..........
There is another line to the thermostat when you lturn it on that opens more gas to increase the pilot to a biggger flame to open the gas valve burner assembly.
.Also ranges usually come set for natural gas, and you have to do spud adjustments, regulator, air flow only if you want to change to lp......
Put a new flex line on, and be careful with gas...........
Jan 04, 2010 | Whirlpool GS460 Gas Kitchen Range
Need to raise pilot flame hugher on burners
Need to check your gas pressure or use a very fine piece of welding wire to clean out the jets
Sep 28, 2009 | Kitchen Ranges
Tappan 24 in. Freestanding Gas Range Kitchen Range Logo
190 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
