Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How to set up cable input on television...searching for channels
We don't have direct t.v, we deal with a cable company, but t.v. hasn't found any channels
  • 179 Answers
The wd52525 has 2 antenna inputs. put the cable in the bottom one first (ant1) press menu, then scroll over to antenna, the scroll to ant1 and hit enter. if none are found repeat using ant2. if none are still found then the chassis is bad or you have no signal. try the cable on another set if it works then visit www.tv-tech.com
Posted on Dec 18, 2008
Just purchased an RCA 32" LED TV from K-Mart. Trying to set-up and in auto-scan it will not pick up any channels
It really depends on how your connecting signal. I am not sure about where you are but virtually all cable companies in Canada require the use of the cable box. Searching channels will only check either the analog cable input or rabbit ears. Typically you hook up the cable box via HDMI and set the televsion to that HDMI input and channels are changed on the cable box.
Dec 07, 2014 | RCA Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
How to connect the cable to my Akai tv set without a cable input? I don't have a cable box.
If you get a cable box that has audio/video outputs on the rear connect them to a identical input on the rear of the set----direct connection and bypasses the coax fitting most sets have.
Go to the input you hooked to and leave set there--change channels via the box with its remote or manual buttons.
May 27, 2012 | Televison & Video
Connected lg tv directly to cable wall jack. Can only get one channel. Manual scan grayed out. Ez scan does not find any channels. Main input is set to cable box. No option for just cable
Why not get a box and hook via rear inputs--not that expensive from most cable companies. If items such as the channel scan are grayed out it means something in the set is set wrong---
Apr 21, 2012 | Televison & Video
The calble is connected directly to the tv, not through the cable box & when i try to change the channel it says "no signal" at the bottom left corner. Olevia 32" model 532-b12
I assume from your question that you have a cable subscription and that you have the cable plugged into the ANT input via a co-ax cable. The ANT input is for an antenna for over-the air signals. The channel up/down change the internal tuner up/down. For example, if your cable is set to channel 3, it will pull in the cable on channel 3, but then try to pull in over-the-air if you hit channel-up to channel 4.
It seems you need some kind of converter box from your cable company in order to change the cable channels, and then that converter box would plug into either the ANT input (and leave the tuner on 3) or into one of the other inputs like Component, HDMI, SVideo etc.
Feb 13, 2011 | Syntax Olevia 532H 32 in. LCD HDTV
CAN ONLY GET CHANNELS 2-13. I HAVE BASIC CABLE
if you have a cable box then you need to put the tv on channel 3 or 4 or an input mode
if you are cable direct you need to access the TV's menu and do an auto channel search after making sure it is set to cable not air/antenna
Dec 03, 2010 | Philips Televison & Video
Plugged Samsung TXC2516 TV directly to cable:cannot get channels
You do have to program the tv in a different search mode, I just checked online and if you go to google and put in manual for and then your tv model it will give you various options so you can download the manual for your tv, or if you want more specific the link that I found was http://www.servicemanuals.net/ServiceManual/SAMSUNG/TXC2516+CX/pos1/results.aspx
Dec 29, 2009 | Televison & Video
Is there a reset default setting?
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
Oct 15, 2009 | RCA Televison & Video
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
White screen with dish network
This is an ancient message so you have probably long since found your problem.
There may be additional input settings to be made since it sounds like the set isn't seeing any input. If you are using the cable input on both the receiver and TV, you will have to set the TV to channel 3 or 4 to see the output of the Dish receiver.
There are three common ways to connect; via the familiar cable in/outputs, S-video with a separate audio cable, and possibly DVI. The TV's input may not search for and find the right input since many sets have a setting via their menu to force the set to look at a specific input.
It helps to have both the Dish manual and the set's manual side-by-side.
May 25, 2008 | Akai LCT2060 Television
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
