Question about Maytag MSD2434GE Side by Side Refrigerator
Maytag refrigerator MSD2454GRW shelf removal
How do you remove the shelves, there are clips also holding the shelves in
thank you
larry
  • Anonymous Mar 26, 2014
    how to release the blue plastic clips to remove shelves
The above answer is only HALF right. The blue clips have to be removed to lift the shelf up and pull it toward you.
To remove the clips:
1. Get a screw driver or something to get behind the clip.
2. Slide it behind the clip and slowly pry it toward you.
3. Repeat for the clip on the other side.
4. Do the above; lift the shelf slightly and pull it toward yourself.
Posted on Mar 02, 2009
  • 8,197 Answers
To remove the shelf lift the back up some and pull shelf straight out.
Posted on Dec 17, 2008
How do you remove a link from the watch band on Model 26551 Thank you, Larry
Usually all watch bands have a pin in each link. Just poke out the pin on the desired link and the attach the desired band length back to the watch face/bezel. Sometimes a paper clip or wire is the only tool you need other than steady hands. Jewelers will also usually do it for free.
Oct 01, 2018 | Miscellaneous
RF197ACRS Samsung fridge How to remove glass from the shelves to clean
Well, I don't know about the individual shelves, but for the long glass shelf above the crisper drawers, there are two white clips located at the back edges of the glass that need to be pried out with a knife blade, or something similar. Place your blade in between one of the grooves of where the clip meets the plastic frame (and, NOT between the clip and glass! ) and pry the clip with a bit of a sideways motion. It's a little stubborn, but if you break a clip, don't worry, you really don't need it for the shelf to function.
Anyway, after you pry up the two corner clips, lift and slide the glass toward the back to get it out of the front groove, and voila!, the glass comes right out.
Aug 14, 2015 | Samsung / RF197ACRS
Plastic door shelves fall out
Try small cable ties if they sit on pegs sticking out you can then cut the ties for removal.
Aug 26, 2014 | GE 21 cu ft Top-Freezer Refrigerator White...
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Apr 21, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Remove cast iron kitchen sink with stainless steel rim and clips underneath
Clips attach to rim and hold sink from below, and rim holds sink from above.
Remove clips and sink will drop down.
Then use putty knife to remove rim from countertop.
New sinks will probably not fit same opening, new sinks are slightly smaller, so measure before removing old sink.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 15, 2012 | Home
REFRIGERATOR AND FREEZER NOT GETTING COLD. ERROR CODE 5Y.MODEL NUMBER LGUS2642LF2 SERIAL NUMBER 4A23305873
That error code is "SY" and not "5Y" and it is for the evaporator sensor error. You will need to replace the sensor.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Access the evaporator assembly cover in the rear of the freezer section. In convertible units that can function either as refrigerators or freezers, and is located toward the bottom of the unit on the inner back wall -- if necessary, remove the two lower glass shelves and the crisper compartments.
Remove the screws securing the evaporator cover to the freezer wall, using a Phillips screwdriver.
Pull the evaporator cover away from the wall just enough to access the electrical connection behind the cover. Be careful not to damage the gaskets on either side of the evaporator cover. Reach behind the cover and disconnect the electrical connection from its wiring harness. Remove the evaporator cover from the freezer.
Remove the wires inside the exposed evaporator assembly from their retaining clips, then squeeze the quick-connect mechanism to detach the wires from the fan motor.
Remove the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using a 5/16-inch socket or nut driver.
Remove the two hex-head screws holding the fan motor to the mounting bracket, using the 5/16-inch socket or nut driver, then pull the fan blade off the motor shaft.
Examine the fan to make sure the blades are not damaged; if necessary, replace the fan itself as well as the motor. Slide the fan onto the motor shaft.
Attach the new motor to the mounting bracket, using the 5/16-inch socket or nut driver to secure the two hex-head screws.
Replace and tighten the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using the 5/16-inch socket or nut driver.
Reattach the the fan motor wires by clipping them back into the quick-connect mechanism, and set the wires back into their retaining clips in the same manner as they were attached.
Set the evaporator assembly cover back into place, then reach behind and connect the electrical connection into the wiring harness.
Secure the Phillips screws that hold the evaporator cover to the freezer wall.
Replace the shelves and crisper compartments if they were removed, then plug the refrigerator into its power source and verify proper operation.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Refrigerators
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
NEED TO REMOVE REAR ROTOR
Take off the wheel, remove the brake caliper (2 bolts on the back), then the rotor just slides off, the wheel studs are part of the hub assembly not the rotor.
Nov 21, 2008 | Hyundai Motor 2002 Sonata
Gas pedal linkage
Don't need a diagram.
Start by checking to see that ur cable hasn't come off the throttle body or that the clip in the floor behind the gas pedal is still there.
If it's broken, remove the clip on the floor and remove from the throttle body. Disconnect the cable from the pedal and pull it out from the inside of the car.
Aug 22, 2008 | 1994 Volkswagen Jetta
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Mar 30, 2008 | Refrigerators
Maytag MSD2434GE Side by Side Refrigerator Logo
3,414 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
