Question about KitchenAid KHWS01PMT Front Load Washer
I turn the control knob to rince/spin, the machine froze
I turn the knob to cycles : Rince/ Spin.After few turns the light starts flashing, 06 F.I cant even turn it off. How do i fix it?
  • 113 Answers
I believe the f06 is a clogged pump. You should be able to take off the bottom panel via 3 screws on the bottom of the panel. Inside should be 3 inch diameter white twist cap. Open it, but be ready with towels cause waters gonna come out. Thats the pump trap, it catches everything before hitting the pump. Hope that helps. Dave www.washermd.com
Posted on Dec 17, 2008
Fisher and paykel model gw712 . During rinse or spin cycle unit goes out of balance and stops. The rince or spin light flashes and a beeping sound is heard.
your clothes load is too heavy on one side; stop it move some around and turn it back on and see if it doesn't wobble all over.
Jun 06, 2015 | Fisher and Paykel Washing Machines
Will not rince at end of wash cycle
If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
Nov 19, 2012 | Bosch Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
Dec 13, 2017 | Whirlpool AWM6120 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Doesn`t finish cycle
Thanks for the information !
Sep 19, 2007 | Fisher Paykel EcoSmart GWL15
KitchenAid KHWS01PMT Front Load Washer Logo
75 people viewed this question
Top KitchenAid Washing Machines Experts
gbob59
Eric Taylor
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
