Question about Acer Aspire 5630 Notebook
Computer wont start
I have a acer aspire 5630 and i tried to import some pictures off a HDD and in the process pf doing that it froze up and when i tried to restart my computer the windows error recovery page came up saying windows failed to start. it gives me an option to start the computer normally or startup repair. when i choose the startup repair option it says windows cannot repair this computer this computer automaitically. i have tried everything and dont know what else to do. is this a problem i need to bring to someone to fix or is there something i can do myself???? please help
  • meaghan0505 May 11, 2010
    i can not get it started in safe mode. i was able to once and then my computer shut down and ever since then i cant even log in to my computer. i have tried safe mode, scaning for problems, everything i think it shows i can do i have tried and nothing is working!
  • Simon Kelly
    Simon Kelly May 11, 2010
    can you boot into safemode? this is done by hitting f8 when the computer is starting up and selecting "boot safe mode"
My acer aspire 5630 wireless divices wont turn on
have you tried opening it on the control panel? please do try.
Mar 29, 2010 | Acer Aspire 5630 Notebook
Acer aspire startproblem no dispaly at all
check the your RAM, or change your RAM if the same problem and try to chek your CPU processor....,
and also your HDD
thanks
Jun 01, 2009 | Acer Aspire 5630 Notebook
Acer One zg5 - updates now wont boot up
Right after the BIOS or POST keep pressing F8 do you get the option to go into safe mode?
Feb 06, 2009 | Acer Aspire 5630 Notebook
How do you fix a frozen mouse for a acer aspire 5315-2077 laptop?
Fn F7 probably got pressed (turns on and off the trackpad. probably the dumbest thing to have a hotkey for)
Jan 16, 2009 | Acer Aspire 5630 Notebook
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
Acer aspire 5630 wont start up. please help!!!
Press F8 key and go into safe mode when u start the computer,tap it a few times until you get the safe mode screen,try choosing "Last known good configuration" and start. If this doesnt work, you can try system restore.
Dec 16, 2008 | Acer Aspire 5630 Notebook
Black screen on acer laptop
this is commonly caused by HDD failure. I suggest try replacing your HDD.
Sep 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5630 PC Notebook Problem
This could be an issue with your OS, you will probably need to boot from windows cd or start in safe mode.
May 18, 2008 | Acer Aspire 5630 Notebook
Acer aspire 5630 BL50
You can try basic troubleshooting. Unplug the laptop, takeout the battery. With the laptop still unplugged, put the battery back in and power-on the laptop. If that doesn't work and you hear no beeping sounds, the motherboard maybe bad and needs replacing.
Apr 05, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
