Question about Dell Vostro 1500 Notebook
Hello, I have a fairly new Dell Vostro 1700, I just moved and can't located my booklets on the computer. I turn on my computer and it starts booting up, it shows me the Windows XP and the line at the bottom starts moving, then as it would normally do, it starts to kick in to the desktop but instead of normal, it now goes to a blank black screen. I have the curser and I can see it move all over the screen but cant do anything. I need help fast as I have to get something off my computer tonight. Anyone know what's going on?
  • mstrfld4 Dec 17, 2008
    Hi Poohawk,
    Thanks for the suggestion. I moved a few months ago (just the booklets are still packed). I have been using my computer on a daily basis since then, in fact I was using it an hour before this happened. any other suggestions? Also thanks for your fast reply.
    Sergeant:
  • 324 Answers
Here's a couple of quick things to try. Remove the memory modules and reinsert them. Do the same with the hard drive, CD drive and such. Something may have gotten knocked loose during the move.
Hope this gets you back up and running!
Ron
Posted on Dec 17, 2008
  • Ron Roske Dec 17, 2008
    OK, I understand the situation a little better. Thought that this had happened just after the move. Don't have any other suggestions right offhand. However,if you haven't tried reseating the memory and hard drive, I would highly suggest taking a few minutes to do that. I have seen both of these cause the problem that you are having. Another thing that causes this situation is something that you wouldn't want to hear. And that is that something in the OS code on the hard drive is cobbled up. Requires a repair or reload of the OS. Not usually good!
    Will check back tomorrow evening to see if you have left any update.
    Till then,good luck.
    Ron
Dell vostro 1700 start buton not working
they do go bad I had a new DELL that the company would not even look at fixing they said it was outdated before walmart sold it to me but if you know how to access bios then go in there and reset to default . save change and exit .
May 02, 2014 | Dell Vostro 1700 Notebook
My Dell Vostro 1700 will not boot up. I've installed a different HD, that didn't work. I've run test with nothing found. I have a protection software and still my system is not working. I need help
Please restart the computer and keep tapping the F8 key on the keyboard once you see the Dell logo unitll you see windows advanced boot menu, choose last known good configuration using your up and down arrow keys on the keyboard. Once highlighted then press enter key. This should take your computer's settings to the last time when your computer was working fine. Also remember to remove any external devices (printers, USB flash memory, memory cards, External hard drive or CD/ DVD drive etc) Also remove CD / DVD present inside the CD/DVD drive.
Dec 24, 2010 | Dell Vostro 1700 Notebook
I have a dell vostro 1700 that will not start with battery in and on mains it goes into diagnostic boot
when you say the battery is in, you refer to battery is actually plugged in while the ac adapter are connected? it means the laptop works fine with ac adapter alone? try updating the bios download from the support.dell.com
regarding the diagnostics. the partitioned where the diagnostics should be into was might wipe out during re-installation or something.
Mar 28, 2010 | Dell Vostro 1700 Notebook
How to activate bluetooth on dell vostro 1700
turn on the bluetooth using the wireless switch located on the left part of the computer. make sure it is on the 1 position not on 0
Feb 19, 2010 | Dell Vostro 1700 Notebook
Dell Vostro 1700 will not shut down - computer restarts when you select shut down option! Any suggestions?
try to press and hold power button for 5-10seconds if it still turns on by itself need to repalce the hinge cover of computer
Feb 14, 2010 | Dell Vostro 1700 Notebook
I could t download attachment even as small as 16kb.It takes ages and would not download at all.What can I do?It is frustrating ! I use a Dell Vostro 1700, with Intel Core duo 1.80Ghz running Windows Vista...
try to turn off security center and any other security software installed in your laptop. if fails. boot to safe mode with networking then try to download again the file. if fails check if other computer can download it successfully using the same connection, router and modem. just to isolate if a security in your router has been enabled.
Oct 10, 2009 | Dell Vostro 1700 Notebook
My screen will not work on my dell vostro 1700
just check your laptop booting is ok or not booting is ok .........then we have provide the link of how to check the screen chane and check the screen problem .............ok dear my solution is 100% working just .....do it
http://www.laptoprepair101.com/laptop/category/laptop-tips-and-tricks/
Mar 27, 2009 | Dell Inspiron 1501 Notebook
Dell Vostro 1700 Microphone
got to start,my computer,device manager, hardware and make sure that your microphone is on. Probably on mute.
Jan 08, 2009 | Dell Vostro 1700 Notebook
Black screen
I had a much older dell laptop (2001?) that did this. For whatever reason it had 5 or 6 drivers loaded for the monitor/display. Of the five, four were identical. I disabled the identical ones and kept the normal one enabled and this solved the problem.
Dec 17, 2008 | Dell Vostro 1500 Notebook
Dell Vostro 1500 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
