Question about Dell 924 All-in-One InkJet Printer
Printer has two smudges in same place every time
Deskjet 6940 prints fine but, has two small smudges in same place on paper every time even after cleaning both cartridges manually.
The reason you see a smudge in the exact same place everytime is due to ink being on the roller. Solution: using good light, use isoprel alchol on a cotton swab to clean the roller. Ink on the roller is also an indication that your head cleaner pad (look really good on the right hand side <inside> for the pad) is dirty. If you've not done so in the past, just flip it over and like magic you have a clean pad...just dirty on the other side.
Posted on Dec 17, 2008
HP deskjet 6940 has been installed. I see it in printers and it says ready but nothing will print to it. On the front of the printer there is a blinking orange arrow. What does that mean?
hello, have you tried pressing the orange button to see if machine will continue and pick up paper and print, also are there any other lights that come on, you might want to take paper out, and turn it around, and install back in. and try again. you might also want to change one ink cartridge at a time to see if that also might be the problem
Oct 01, 2010 | HP Deskjet 6940 InkJet Printer
Hp deskjet 6940 paper jam light blinking every time i try to print. no paper jammed, have opened and closed all doors, turned the wheels as the other help indicators say, but still it will not print. ...
This past Saturday we just had a similiar problem on our church HP printer. Different number than yours, but most likely the same solution. It jammed when the last person used it, so they removed the crinkled paper. Or so they thought - there was a piece maybe 1-1/2" triangular shape stuck on top. I liked to never found it, I looked even with a flashlight 4 times before I caught just a hint of white way up there. If that is not it, there could be a door you have not opened. Most of them open top, back, front. Ours also opens on the side. The back opens in two places. Occasionally there can be a piece of paper you can only see from one door.
Dec 14, 2017 | HP Deskjet 6940 InkJet Printer
HB Deskjet 6940 Won't Print - Windows 7
To solve this problem do the following steps :
Start -> Run -> Type services.msc -> in the service consol find the print spooler service and check is it started or not if it is start then right click on print spooler and click on restart.
If the print spooler service is stop the right click on print spooler then click on the properties, in properties click on start.
Your problem should be resolve.
Regards
Ashly
Feb 04, 2010 | HP Deskjet 6940 InkJet Printer
Error message
Uninstall the printer driver from Device Manager, then scan for hardware changes and install the printer driver when it detects the printer...All the best
Oct 02, 2009 | HP Deskjet 6940 InkJet Printer
Orange button continuously flashes on HP Deskjet 6940 printer and printer will not print.
it is problem ink cartridge or paper miss feed please chack it and solve your problem
thanks
Tareq
Jul 31, 2009 | HP Hewlett Packard Deskjet 6940 InkJet...
My hp 6940 wont print at all. it goes through the motions but paper comes out blank
First your printer off and on after remove old documents and give a new print.
Jul 07, 2009 | HP Deskjet 6940 InkJet Printer
Install cartridge missing on Deskjet 6940
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | HP Deskjet 6940 InkJet Printer
HP 6940 rejects 8.5" X 11" glossy photo paper for printing
Is it a front feed and then the output is also goes out to the front? Coz if your glossy paper is to tough that it will not bend easily, this is what you get. Why not try to use a thin and more flexing photo paper if the outcome will be the same.
Usually when using thick paper the most desirable printer should be a top feed-front output with almost less than 90 degree bend.
Apr 24, 2009 | HP Deskjet 6940 InkJet Printer
Cleaning the printer heads
use the deskjet 6940 toolbox that should be loaded. You should find it in the driver, look for a maintanance tab.
Oct 15, 2008 | HP Deskjet 6940 InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
207 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
