Question about Pioneer XV-HTD520 Multi-disc DVD Player
Pioneer DVD tray won't stop in 'out' position
I have a Pioneer xv-htd520 5 disc dvd/cd player. When I press the open button the carosel tray comes out and then goes right back in. I can only load disks by manually holding the tray out (fighting the tug of the motor) for a few seconds, after which it stays open. This happens regardless of the number of disks, including none. I took the cover off and it looks clean inside. I ran a cleaning disk with the little brushes (no liquid solution), but nothing changes. I bought this used, and suspect possible shipping damage, but the problem took a couple weeks of constant use to develop. Any suggestions would be appreciated.
  • 2 more comments
  • Anonymous Jan 04, 2008
    We have the same Pioneer XV-HTD520 5 disc dvd/cd player. When we press the open button the carousel tray comes out and then goes right back in. I can only load disks by manually holding the tray out (fighting the tug of the motor) for a few seconds, it never stays open. This happens regardless of the number of disks, including none. Bought new, and suspect possible electrical problem due to a power spike awhile ago otherwise it works fine. Any suggestions would be appreciated.
  • Anonymous Mar 30, 2008
    Same problem. And one of the speaker outputs no longer puts out. I am scrapping this system.
  • Anonymous Jan 04, 2009
    i have the same problem. what i do is use the exchange button to load and unload discs
  • Mike Lambert
    Mike Lambert Nov 09, 2012
    My unit closed immediately upon opening since like 1 day after the warranty ran out. It bothered me. I finally tore it apart and this fixed it. Take the cover off. As you are facing the front of the player, the blue sensor switch that controls the tray will be on your left in the middle of the carousel. Push button to open tray and locate it as the tray opens. Grab the tray and also the carousel and hold them so you can see the little blue switch. Use a tiny screwdriver or toothpick or other slender device to "flick" the switch fully forward and backward several times. Let go of the tray and try the button. If it still closes immediately, repeat the flicking. Try it again.
My system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Posted on Jan 29, 2009
I had the same problem with my unit. Was fixed easily by applying switch cleaner to the tray position switches.
Posted on Jun 26, 2008
My DVP-NC600 CD/DVD player will not recognize discs inserted. The carosel just spins freely and won't stop. HELP!
Welcome to fixya!
open up the screws , if you can check the tray if there is something inserted remove it and its ready to be used again ,
the reason is something is struck inside it may be a disk or something .
Check if helps you in any manner
Apr 30, 2011 | Sony DVP-NC600 Multi-disc DVD Player
I have a pioneer dvd/cd receiver player,,, xv-htd540 and the timer light is on,, and the unit wont turn on..
i don't have a solution , sorry . but i am looking for a user manual for the xv-htd540 . do you have one ?? dennis
Jun 01, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
Lock
The disc lock function has been activated on your JVC XV-N320, when in this mode the tray cannot be opened or closed.
If you press the 'eject' button whilst pressing down the 'stop' button on the machine in standby mode the disc lock will deactivate. To turn it back on you follow the same procedure. This is also described in the user manual for this model of TV umder trouble shooting on page 13.
Hope this helps,
James
Apr 23, 2010 | JVC XV-N320 DVD Player
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
I have a xv n330 dvd player and it says lock when I try to take out the dvd in the player and it says lock.
When you press the eject botton while pressing down the stop botton on the unit in
standby mode, the tray lock function is activated. The disc tray
cannot be opened or closed in this status. To release this
status, press the eject botton while pressing down the stop botton on the unit in standby
mode.
Mar 01, 2009 | JVC XV-N330
Pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Dec 12, 2008 | Pioneer XV-HTD520 Multi-disc DVD Player
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Need to reset my dvd player
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Feb 28, 2008 | Pioneer DV-285-S DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Pioneer XV-HTD520 Multi-disc DVD Player Logo
547 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
