Question about Refrigerators
My fridge and freezer stops working periodically.
Whirlpool ED22LF will stop running and I turn it up a notch and it starts back up. It will run for a couple more days and then goes out again. I was thinking it was the thermostat? Would this be something I could fix myself or do I have to call someone?
Thanks, Single Mom.
3 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool Refrigerator - Model# ED22LF
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
Posted on Jun 28, 2008
heatman101
  • 43501 Answers
SOURCE: Whirlpool fridge/freezer not cooling
Here are a couple of tips that I wrote that will help you figure this out...
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
heatman101
Posted on Apr 27, 2010
Should the fan operate all the time in my refrigerator
Most of the time it runs only when the compressor is running. In other words compressor and fans will run together when the fridge thermostat ask for cold and stops together when thermostat is satisfied. In newer fridges some time inside fan (evaporator fan) might PERIODICALLY run without compressor to circulate little cool air to fridge compartment from freezer compartment.
Sep 30, 2014 | Whirlpool Refrigerators
The cooling unit stops running periodically.....long enough to allow food in the freezer to thaw. The fridge light is on, so electricity is getting to the fridge. The previous tenant had dogs, and when we...
Could be defrost sticking or the compressor not starting...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
The freezer is working yet the fridge is not I
pull the frig out from against the wall and unplug then remove the cardboard backing be carful your going to put it back on and see what got lodged into the fan blade that cause it to stop when you cleaned the coils remove the object and plug back in ensure the fan start up put backing on push back
Aug 20, 2009 | Refrigerators
Have a Whirlpool refrigerator that has stopped
replace the electronics on the compressor --if you would like more tech diagnosis let me know
Aug 10, 2009 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Jun 28, 2008 | Whirlpool EL02CCXP 19" Cold Pals Compact...
Whirlpool freezer and the refrigerator.
Chances are your defrosting clock is stuck or quit working.
The clock works as timer to set time for defrost, at which time it stops the compressor, and turns a heater tube next the cooling coils to melt ice. It depends on your expertise if you want to try replacement,as most replacement are universal, and some rewiring is sometime involved. The clock is usually in front at the bottom behind the removable grill, or in the back. It looks like a square box with a dial that has a one way turn knob. To check use flat screwdriver to slowly turn dial (you can only turn one way) until the compressor stops, then wait to see if compressor starts back on it's own (it might take as long as 30 min.).
If it does not start it's bad and need replacement. Of course you can turn dial again until it starts again so you can use fridge. If it does start it could still have been the problem where the clock got stuck, and you got it going again by turning the knob, but let it run. If it works for a while and then have the same problem again the replace clock.
Hope this helps you
Dec 12, 2007 | Whirlpool (ET8FTEXSQ) Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
