Question about IBM ThinkCentre A51 PC Desktop
ThinkCentre won't start up. Absolutely nothing on monitor. Fan runs, green LEDs on face light. Reseated all drive data and power cables. Reseated memory.
  • m3sellers Dec 17, 2008
    No, I don't have any external cards. I haven't made any hardware or software changes to the machine for a long time.
    Problem Solver:
  • 14 Answers
Do you have any external cards that you have installed into this PC? Like a new graphics or sound card? If so try pulling them out (actually you may want to try pulling all the cards out of the PC).Please make sure the PC is turned off and unplugged from the wall before doing this.
You would only need a display card in there and if it has a built in one on the motherboard that has not been disabled please try to use it.
Let me know how this works out.
Thanks,
Kaj
Posted on Dec 17, 2008
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
A computer with a D101GGC motherboard does not start. There is no beep or monitor singal. The fan is okay. As soon as the power is connected to the computer, the red drive access light comes on, but not...
its a common problem with intel D101GGC motherboard, just open the case and unplug the dvd power cable and data cable, then turn on the PC it will work fine.
Jan 09, 2011 | Intel D101GGC Motherboard
It will not start even after I replaced the power
Before anything else, open your case and make sure all power and data cables going to motherboard, disk drives, etc are firmly seated, and remove and re-install memory sticks in the same locations. Sometimes temperature changes inside the PC can cause these connections to loosen. If that doesn't fix it, do you hear the noise of the cooling fans coming on? If you do, check your monitor for a green light. If you get a green light on the monitor and fans are powered up and running and you get nothing else it could be a hard drive issue. Try booting from CD in that case. If fans come on briefly and then shut off, or fans stay on and you have no green monitor light, this could indicate an issue with your processor or motherboard.
Jun 04, 2010 | Dell Dimension C521 PC Desktop
Acer One 1542 series.Power on but not boot.
since you reseated the memory, the last two things I would do is remove the hard drive and dvd drive.
If you remove those and you can't get video then the motherboard is bad.
Aug 03, 2009 | Acer Aspire One PC Notebook
Device powers on but will not boot
I have seen this happen when the amount of RAM installed in the computer is higher than what is allowed by the motherboard.
Jun 28, 2009 | Acer Aspire 5315-2153 Notebook
Compaq 5002US PC won't boot (not even BIOS); no sights or sounds
if the processor was fried, it would not boot at all. i take it that you cannot get into bios? perhaps bios is currupt.
Mar 21, 2009 | Compaq Presario 5000US (D70008-261) PC...
Turns on, then shuts down before anything shows on monitor
Is there more than one fan inside the computer? Did you double-check the connection from the fan to the motherboard? Sometimes a computer will shut down if it doesn't sense that the fan is turning on, to prevent the computer from overheating.
Jul 25, 2008 | Compaq Presario S5100NX (E120866) PC...
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
IBM ThinkCentre A51 PC Desktop Logo
385 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
